I sanded down and primered and painted the cam gear cover to fix the flaws. I also paint the 2 bolts that hold it on along with the top bolt that holds down the passenger side light cover. I finally took a dremel to my DS headlight mounting bracket to enlarge the holes so I could better position the headlight. And I discovered in my trimming of the air intake pipe that I do in fact need the Driftmotion pipe again, although shortened and without the 3 nipples since it has the perfect bend that I need.
