Pre-lube Suggestions
Status
Not open for further replies.
supraguy31
626
Pembroke, NC
Ok all, I need to know what type of lube do you all Put on your Pistons, Cylinder walls, Rod and Main Bearings before you torque everything down. Basically, So you dont have Dry Startup on a freshly rebuilt Engine.
Robert
Straight 30W motor oil ;)
Using ARP hardware, I use the supplied moly for the threads.
supraguy31
626
Pembroke, NC
Someone told me that there was a Specific type Lube that you were to use so everything spins freely. When I put a Breaker bar on the Crank and turn it, Its Extremely tight but this was before I put any Lube on anything. Pulled the motor back out, and in the Process of lubing everything. I was wondering why a Brand New Battery couldnt get it to turn over..
Robert
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Go to the pars store and buy Lucas oil stabilizer, comes in a white bottle thing. It's like oil, but won't break down as fast. It's more like honey so it sticks well to the pieces you apply to.
eric
chriso
Supranian
Bay Area, CA
I've used Red Line Assembly Lube on all bearings and camshafts very liberally. The stuff is reddish pink and you can get it at any parts store. It sticks to everything but is oil soluble and you'll be rid of it after your first oil change. Just make sure everything is spotless because dirt will stick to the stuff. I use straight 10W/30 on the piston rings and cylinder walls during assembly.
bigboost7m
67
Center Line, MI
Robert
If your motor was that tight, you might have a clearence issue. The motor should spin freely even with light lube on it. If you still have the motor out double check the bearing clearences with plastigage, it will save you a big headache in the end.
8,897
Lubriplate 105 is what the proffessionals, such as myself, use for lube on the bearing surfaces. Nothing on the cylinder wall. You are trying to seat the rings, not lube them.
PorterzSupra
703
Hebron CT
Nothing on cyl wall!!? that seems kinda ruff.
Stretch
Toronto, Ontario
It has to be rough, it has to set the rings. If it glided smoothly the rings wouldn't set properly and you could enjoy oil blowby for the life of your motor yay!
eric
suprarich
Guest
Nov 9, 2005
2,187
ohio
Clevite 77 made an assembly lube in a squeeze bottle that works very well for me. I have used it in every thing from my race bikes, 7m's, small engines, to all the diesels at work. Always worked well for me. Just choose one that has a proven track record.
mickyg
7MGE MX-73
Sep 15, 2005
406
Melbourne AU
So Nick, if someone knows they'll be taking a long time to complete a build, and they're trying to minimize rust forming on the cylinder walls, so have applied oil to the rings/pistons for that purpose alone, what would you recommend to remove the oil before assembly is complete? I'm thinking brake cleaner or carby cleaner.
BJ91T
810
Baton Rouge LA
Dont use motor oil as it burns and turns to carbon all in your rings on startup.WD-40 FTW!! just dont let the motor sit to long before you start it
8,897
I haven't been in that situation. When a block was returned from the machine shop, the customer has usually been waiting a week or so already. It is assembled the next day, or later that day depending on when it is returned.
WD40 and a plastic bag I guess. I suggest not machining it if you are not ready to assemble.
mickyg
7MGE MX-73
Sep 15, 2005
406
Melbourne AU
So definitely clean it all off in my case then. Before I put the head back on, I'll make sure the bores and rings are dry. Thanks for the advice!
Status
