Ok all, I need to know what type of lube do you all Put on your Pistons, Cylinder walls, Rod and Main Bearings before you torque everything down. Basically, So you dont have Dry Startup on a freshly rebuilt Engine.
Robert
Robert
supraguy31 said:Someone told me that there was a Specific type Lube that you were to use so everything spins freely. When I put a Breaker bar on the Crank and turn it, Its Extremely tight but this was before I put any Lube on anything. Pulled the motor back out, and in the Process of lubing everything. I was wondering why a Brand New Battery couldnt get it to turn over..
Robert
slacker said:I used lubraplate for years ..BUT .. this is the stuff to use now .. Lucas oil treatment .... http://www.lucasoil.com/products/display_products.sd?iid=25&catid=2&loc=show its bar NONE ... the best .
Nick M said:Lubriplate 105 is what the proffessionals, such as myself, use for lube on the bearing surfaces. Nothing on the cylinder wall. You are trying to seat the rings, not lube them.
So Nick, if someone knows they'll be taking a long time to complete a build, and they're trying to minimize rust forming on the cylinder walls, so have applied oil to the rings/pistons for that purpose alone, what would you recommend to remove the oil before assembly is complete? I'm thinking brake cleaner or carby cleaner.Nick M said:Lubriplate 105 is what the proffessionals, such as myself, use for lube on the bearing surfaces. Nothing on the cylinder wall. You are trying to seat the rings, not lube them.
mickyg said:So Nick, if someone knows they'll be taking a long time to complete a build, and they're trying to minimize rust forming on the cylinder walls, so have applied oil to the rings/pistons for that purpose alone, what would you recommend to remove the oil before assembly is complete? I'm thinking brake cleaner or carby cleaner.
