91blackeye;1660325 said:I hella appreciate the assistance and moral support man. I have been talking to one of my friends, he has a 400 SBC in a 69 firebird. He said TOTAL rebuild with nice pistons, rods, the whole deal only set him back 2100....So....I might be able to have this done the right way....if I am not in prison for murder.
Devin LeBlanc;1660350 said:I win... On several levels
Devin LeBlanc;1660345 said:I do oil changes every 2000 miles, check the oil EVERY single day maybe even twice a day.. (no one can say I'm over protective either) were talking about a 7M here..
Supra0089;1660476 said:Dropping in a used 7m might be the easiest solution.
i dont think he has the knowledge for that swap...niether enough money.to support itspikesnstuff0905;1660490 said:He can probably find a 1j for cheap as well, i'm sure there are people getting rid of them to swap to 2j.
hvyman;1661368 said:^lol.
I would not drop a jdm motor in without inspecting it first and at the least putting a new hg on.
91blackeye;1661852 said:So, I forgot the camera I borrowed from my friend ashlee at school, like a dumbass, but i have made progress on the car. I took a bunch of crap off, and drained the oil, and radiator. went fishing in both fluids with a magnet, found zero metal bits. there were very very small bits of rust in the radiator, which i found odd, as it is aluminum, but I found the thermostat was slightly rusted. So, I attribute the rust in the rad to the thermostat. Had it running before i ripped it apart, and my gf's grandpa, who has done a hundred billion trillion motors in his 72 years of life, says it sounds like one single bad rod. I wasn't thinking before hand, otherwise, i would have pulled each spark plug one by one until the knock got more quiet....but, anyway....motor should be out tomorrow..
Supracentral;1661938 said:Read this:
http://www.supramania.com/forums/showthread.php?t=20486
Specifically the section towards the bottom titled "Commentary on rod knock after a Head Gasket swap"
It may help explain a few things, including why your supposition about the source of the rust is likely wrong.
