I just thought people thinking of upgrading their turbos might want to see the difference between stock and the 57 trim. This was done by Driftmotion.
:nono:RiyadYar;925179 said:so what exactly is the difference? do they just change the size of the opening?is the turbine changed?
forcefedsupra;925747 said:Someone used to make steel braided oil lines for the ct, does anyone still make that?
rumptis;925830 said:I'm not 100% sure as I'm waiting for mine to come back but I don't think the exhaust turbine is touched unless you get it cliped.
Its just the compressor side that is changed and the housing bored out. Basically everything you see different in the pictures above.
marc3;944336 said:i also noticed that the vacuum port for the wastegate is at a different place.
any reason why?
Nick M;944375 said:For the 89 model year, Toyota redid the actuator and set up for faster spool.
forcefedsupra;927046 said:
Rennat;944483 said:really? any "hard facts" to support this??? Just curious is all...
