cadman;1083705 said:
And maybe this will help ya out. Here's what I did! I asked myself these questions; What will I be using this car for? Every day driver or weekend warrior? Maybe a track car? I wanted my car to be an everyday driver if needed. Ok that means reliability. How fast do I think I want to go? Um, I wanted to hit low 13s, maybe high 12s in the 1/4. Ok, I'll need a bit over 400HP. Alright, I started with a good base, a strong inline turbo 6. What do other people do to get their cars to this point, and what do they think of their finished project.
Now figure out what you can afford. Do it right the first time. I've never heard someone say "Man I'm so glad I settled for stock pistons and rings, and then over-boosted."
Figure out what you want man. And during this whole project, you'll learn a ton.
Well ive been looking at a few builds. I know my goal is somewhere between 450-500 horsepower. Here's one build I found form a guy that was selling his 450 horse supra......
1990 Supra
Turbo
5speed
White exterior
mix blue and grey interior
Targa top
Engine is FULLY Rebuilt ENGINE less than 15k miles
Shell
White Exterior
Aftermarket antenna
New VIS carbon fiber hood
NO MAJOR DENTS/Straight Body
Drive Terrain
H&R Springs With tokico blue struts
Power slot and drilled rotors and porterfield rs4 pads
Magnum SS Brake lines
rear diff is filled With royal purple
stage 3 proclutch 6 puck sprung
Gauges
AEM uego wideband
Autometer Oil Press Gauge With SS line instead of nylon
Autometer Boost gauge
Autometer EGT Gauge
Autometer Water Temp Gauge
Custom Mounts
Electronics
hks vpc with both 550 and 440 chip
Apexi SAFC 2 fuel COntroller
Apexi AVC R boost controller
HKS Turbo Timer
MUSIC
Jensen MP5720 Head Unit
Sub/amp wires are there.I will be keeping my amp and sub
Upholstery
Tekniq 500 removeable steering wheel and hub
SOGI short Shifter
Blue Interior with: Grey trim and seats.
relocated battery to the Trunk with taylor box
Engine Specs
Work done at mMchinetech Racing in oceanside California
The block is .080 over with custom 85mm forged pistons
All NEW clevite bearings
New oil pump, water pump
new Timing belt
Cometic 2mm mhg
Mild port and polish on the head
New valves
Rotating assy balanced.
Fuel
New Walbro fuel pump with 12v fuel pump mod
areomotive Fuel Pressure regulator with ss lines
550cc injectors
Turbo
hks sportkit t04e 57 trim Fresh rebuilt by Jon at MDCmotorsports
hks long runner manifold with hks 50mm w/gate
3" Half Downpipe & dumptube. Unfinished DP
wiring
new 90 eng. harness from Champion Toyota less than 5k miles
5-speed turbo ECU
Intake
apexi intake
Front Facing Intake Manifold with 70mm ford tb and tps
Intercooler
Greddy fmic with hardpipes
new tial 50mm bov
ETC
oil filter relocation kit with thermo and cooler socketless hose with an fittings
Custom Cold Air Box
Custom IC block OFF plate
New speedo cable
Aftermarket Catch can
The bad
No ac
