hahha.... so i went to toyota, estimate of repairs is $8906 including parts and labor
so hopefully i can get at least 50% of that and fix my shit
And what reason would that be?Supra86Point5 said:90915-YZZD1 or 08922-02011. I only use Toyota filters for a reason.
OneJoeZee said:And what reason would that be?
Nick M said:The second part number listed is one of the Japanese filters. They aren't available anymore in the US as far as I know.
MmmBoost said:hahha.... so i went to toyota, estimate of repairs is $8906 including parts and labor
so hopefully i can get at least 50% of that and fix my shit![]()
Doward said:Jdub, what about the Champion Labs built filters? (Mobil 1, Bosch, etc) I've been using the Bosch filters for a few years with great results thus far![]()
Poodles said:shouldn't the BPV have stopped the filter from bursting? defective parts do happen, but this sucks...
Tundra Solutions Website said:DENSO 150-1003 Cost: $9.50
Made in U.S.A.; also marked 115010-4190
Pleated filter, 0.033” thick, resin-impregnated synthetic and natural fibers. 46 pleats, 13.5mm deep, with 66mm height. Seam is sealed with crimped metal, and ends of pleats are sunk in hard sealant, enclosed in metal caps.
Total area = 0.081 sq. meter.
Eight entry holes, showing red silicone rubber ADB valve. Looking thru the outlet, the bypass valve’s metal cap can be seen at the far end. Bypass valve seat is a hard synthetic material.
Seating gasket is round O-ring, not crimped, 71mm O.D. and 64mm I.D.
The steel housing is very strong, 0.018” thick.
Filter has “torque-stopper” flange that seats hard against the engine’s mounting flange.
This filter is similar in internal construction to the PurONE filter listed below, but with a stronger housing and more filtering surface.
