yea....rust=very bad... look on ebay they have foglights ocassionaly with the mounts...thats what you need
7MSupraGE87na said:MS, thanks for the description of wiring the fan, will it be hard to get to the red wire? there is a red wire that stick out of my firewall that just kind of hangs there and isn't connected to anything, could that be the wire you are talking about?
There are also red wires that were cut and electrical taped at the ends connecting my fog light wires.
....NO that is not the wire. Don't know what that wire is. Take some better pics of your engine bay and post em. Fog lights were probably rigged up to work after rust killed the connections or some aftermarket application. And yes those are the proper lights you NEED. get them!
The wire of which I spoke is on the harness on the back of your radio. All you have to do is remove the ashtray, remove the 4 screws there, remove the 1 screw on the driver side of the shifter pannel and pop it out, remove the 4 10mm bolts holding the radio bracket in, and take out your radio and look at the harness pluged into it. It has 1 red wire...not any other color just find the red one. You want to splice off of this wire. dont cut too close to either end or just get one of those wire taps from a parts store; real easy to do.
Soundwave Superior, ms07s inferiorms07s said:Soundwave is pulling the pipe and will have it to me sometime this week then I will ship it to you. Pics? Fans working yet? Other issues resolved yet?
Yea^^^^^^ like that!Kckazdude said:http://www.dodgeram.org/tech/repair/elect/splice.html
Sometimes some pictures are worth a thousand words.
