CajunKenny;1697986 said:
The Maft Install Instructions say to tap the MAP Sensor to FPR Vac. When I inquired about that, Bob said that it was that line sees vac first. He also stated that T-ing it on the back of our plenum has a potential for problems because of the "pulses" from cylinder 6.
I and many others have ours T'd into the Plenum...
What is the MAP Reading at 'Key-On'? He could have one of the bad MAP Sensors.
Maybe he can post up a pic of his sensor...?
So it should be T'd off the AFPR? Hmm yeah I can see the potential, I have not seen any problems that I have noticed, but this is good info...
It was reading IIRC 101 at KO, so I think it is ok and as you see with his latest post, I think he is saying that the gauge and MP are now reading about the same...
Thanks CJ...
---------- Post added at 11:41 PM ---------- Previous post was at 11:39 PM ----------
jdmfreak;1697992 said:
Well I hooked it up like my diagram and had a buddy watching my boost and my afr.... I didn't have my comp with me ... he said he saw my boost hit 14 psi on the maft and my afr between 10and10.5 so you were right about that but I will move those to the front of the manifold does itmatter where the bov goes???
Sent from my DROIDX using Tapatalk
So they are now close to matching - correct? (They being gauge and MaftPro) If yes, then good. BOV just needs to connect to a primary vacuum off of plenum (you no longer have the metal vacuum splitter that IIRC BOV connects to stock), I do not recall hearing any compressor surge, so I think you were good there... of course not sure if I would have heard it over that 4" SP ;-)
And of course as we knew already you are still on the rich side, but I would leave it there until you get some of the other things straighten out before you can begin fine tuning and leaning that out some...
