Well, i've pushed myself to the absolute limit physically, trying to get this damn thing sorted out.
So far, i've done nothing of consequence, barring an oil change. Could i get the filter off? NO.
I needed to drive 73 miles (round trip), to pick up a tool that would fit on the Toyota filter. Of course, when i got back, i found out that not only was the filter thats on there NOT a Toyota filter (and therefore a different size), i couldn't jack the car up high enough for my damaged ass to squeeze under there. How the FUCK are you supposed to get that damn thing off? Cant reach it from the top to twist, and can't reach it from the bottom (as far as i can see). I wanted to remove the filter head, remove the whole damn unit, and unplug the oil cooler - but it's -6 outside, and i couldn't feel my fingers after about 10 minutes of fumbling in the freaking cramped space.
AARGH! I am NOT amused :nono:
However, i got the garage i borrowed the tool off to check the oil pressure with THEIR gauge - just to see where i stood. With the new load of 5w30 in there, here are the results:
Hot Idle: 5.2psi
1000rpm 8.3psi
2000rpm 23.0psi
3000rpm 27.4psi
4000rpm 32.7psi
5000rpm 36.5psi (fluctuated)
Clogged Filter, Worn Bearings, or Pressure Relief Valve? Place your bets.
