Oil pan gasket or gasket maker?
PorterzSupra
703
Hebron CT
I need to replace my oil pan gasket, it looks like from the factory they use gasket maker instead of a gasket, what would hold better should I use a gasket or gasket maker to make my own seal?
jimi87-t
1,127
Colorado Springs
NOTHING will hold better then factory FIPG.
Go to Toyo and pick up a tube or two, the stuff is 10000xs better than normal auto sealant.
Only "issue" with RTV compared to the Toyota FIPG is the RTV bonds and is really hard to make let go if you have to pull the pan later on!
(I trashed my old steel pan pulling it off)
Loki
The Future is Unwritten
Prince George, B.C.
I had the same problem taking mine off, it was such a bitch to take off. I had to stick a knife through and then go around the pan with the knife before it would even start to move :icon_mad:
suprarich
Guest
Nov 9, 2005
2,187
ohio
Heat is your friend to remove parts held together by rtv. Just run your tourch around the flange on the oil pan. It will peel right off.
PorterzSupra
703
Hebron CT
******* the turbo pan does not fit the na block guys... the oil pump is off center, im doin a NA-T in my turbo body, I was told 2 use the turbo pan but it dont fit the NA block what now?*********
shaeff
Kurt is FTMFW x2!!!!
11
Around
FIPG all the way. screw RTV in this case. i use FIPG for almost everything that i USED to use RTV for. :p
-shaeff
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
im not sure what your saying im using an n/a oil pan on my turbo block, and the n/a pan already had the provision for the oil return line.
fits fine
Try turning it around........:nono:
Same pan rails on the block same pump mounting they're interchangeable.
billspreston01
555
North Carolina
I have no experience with the FIPG yet...but let me tell you, I used RTV and my oil pan is leaking ALL THE WAY AROUND...I have to pull the engine JUST to fix that. S-U-X....get the FIPG
oldschool85
1fstmk2
Denver, PA
use toyota FIPG or Permetex FIPG will do the same.
The turbo pan WILL fit the NA black. Same flange pattern all around, the only thing different is the center sump. If it doesnt fit then use the front sump oil pan but it should fit with a center sump. Using the front sump on the MK3 will not fit cuz it will hit the xmember.
charlie
PorterzSupra
703
Hebron CT
I have it the right way, for some reason this NA block has a different oil pump position. The 2 pans turbo and NA have oil pump hoes cut in completely different positions. The NA block has a big hole in the center for the pump and the turbo has a small hole cut on one side. Guys im not crazy the NA and turbo pans I have are completely different!
jetjock
creepy-ass cracka
9,439
I also recommend FIPG when possible. That said, I've done two using aftermarket gaskets without leaks. The key is surface prep and proper torque. Usng a sealer like Permatex Aviation is good too. Also, although it may be obvious to most, when using FIPG on any surface be sure to run the bead around the inside of any bolt holes.
You may have a PICKUP from a centre sump motor...
The Block and Pump mounts are identical between NA and GTE.
Try swapping out the pickups and make sure you use a new O-Ring (it should be in the gasket set)
