Oil pan gasket or gasket maker?
shaeff
Kurt is FTMFW x2!!!!
11
Around
the turbo and N/A body's /chassis are identical. the only thing that changed was the crossmember in 1989...
-shaeff
supra90turbo
shaeff is FTMFW!
32
MA, 01440
IJ. said:
You may have a PICKUP from a centre sump motor...
The Block and Pump mounts are identical between NA and GTE.
Try swapping out the pickups and make sure you use a new O-Ring (it should be in the gasket set)
PorterzSupra said:
I am gonna try using the NA pan and ill see if it works in the turbo body
Ian, all I can see is this.
