I want to run my supra at the local strip and i am afraid of getting booted while waiting in the stageing area due to dripping a few spots of oil. with that said:
Ive recently replaced my valve cover gaskets and all of the hardware that holds them down. i have also replaced the o'ring that is on the CPS. so now all of my leaks are gone from the valve cover region of the motor. doing that, cleaned up the burning of oil under the hood.
i still drip some oil [not alot] when the car sits still. it is really not alot of oil, but if the car is sitting at the track for 20 minutes at a time waiting my turn, it could make a small spot. im curious as to what else could be dripping oil.
my engine bay is covered in some oil grime and sludgy crap because i have not been able to find the entire leak and keep the engine bay clean.
when i look under the car, it looks like it is dripping from the "frontisht" of the engine. closer to the front of the oil pan or so. i cant see the exact cause of the leak because it drips slowly and it seems like it just drips off of other parts.
oil pan seal/gasket? what else is a common "leaker" of oil on our 7m-gte's?
-Tyler
-Tyler
