Actually a good question
The TB PCV fitting has an orifice that limits the amount of boost pressure. The pressure that does get by helps move the oil vapors to the accordion hose with kind of a siphon effect as the flow passes over the outlets on the cam covers. This path is not as efficient as the reverse when plenum vacuum pulls oil vapor to the TB, but works.
BTW - the TB orifice can clog...it's one of the things I clean when I have the TB off the car.
