i havent posted any updated pictures here in a while, but over the spring break i got a good amount accomplished, i got the transmission and engine together, got the fuel pump holes drilled, exhaust system is dropped to further modifications, the fuel tank is sumped, the engine is now in with the transmission, got 25FT of -10 hose and all my fittings, got a LIPP high flow fuel rail and 100 and 10 micron aeromotive filter's ordered and on the way, -8 fittings all around because im doing the dual feed. -6 return.
i currently am going to start working on the engine harness to lengthen any wires that are needed. get it set as if it were going to be started the next day, test my electrical system.
things that need to be done still, oil cooler and lines/ new turbo and wastegate / feed and drain / route all the fuel lines / mount all of the hardware / paint gas tank / run around in a couple of circles and scratch my head.
and now for the pictures
now i know someone is going to ask about the sump and what is up with it, well it ended up the metals were different and made it a pain in the ass to weld, but we got it on made it bullet proof as possible and filled it with water, we found small leaks on it and tried to get it fixed up as possible but it just ended up getting more and never seemed to end, so to make it solid and not leak, and also make it look nicer when it gets painted we bought 4 things of J-b weld :biglaugh: yes it is a little rigged but it works. just have to sand it all down now
