grimreaper;1379220 said:you can "walk" the car up to 4000rpms with minimal throttle which means little load and no positive pressure. The motor has to be loaded to build boost.
boostin300;1380228 said:Yeah, if you're never breaking vac getting into boost then your wastegate is severely stuck open lol.. like a lot stuck open. Even if the seal was bad and it was leaking a little.. you would still boost up. The thing is, even if your tune sucks the biggest balls ever you still have exhaust coming out the motor so your turbo should still spool up.
1) Vac leak somewhere, causing gate to stay open
2) Gate sucks and stays open, could very well be a broken spring
3) Valve in the gate is broke in half or something so exhaust is getting by
4) You have a giant leak somewhere in the intake tract.
5) Your boost controller is goin nuts making the gate stay open somehow.
Either way, if you KNOW you have no HUGE leaks in the intake tract (giant hole in your IC piipes??) then your gates busted to hell or something affecting the gate sucks.
so if visual inspection fails, hows a good way to test to see if the wastegate is opening and closing?
