no boost? Do I have a turbo?[fixed, w/ new problem]
MA70Snowman
374
San Diego
grimreaper;1379220 said:
you can "walk" the car up to 4000rpms with minimal throttle which means little load and no positive pressure. The motor has to be loaded to build boost.
boostin300;1380228 said:
Yeah, if you're never breaking vac getting into boost then your wastegate is severely stuck open lol.. like a lot stuck open. Even if the seal was bad and it was leaking a little.. you would still boost up. The thing is, even if your tune sucks the biggest balls ever you still have exhaust coming out the motor so your turbo should still spool up.
1) Vac leak somewhere, causing gate to stay open
2) Gate sucks and stays open, could very well be a broken spring
3) Valve in the gate is broke in half or something so exhaust is getting by
4) You have a giant leak somewhere in the intake tract.
5) Your boost controller is goin nuts making the gate stay open somehow.
Either way, if you KNOW you have no HUGE leaks in the intake tract (giant hole in your IC piipes??) then your gates busted to hell or something affecting the gate sucks.
so if visual inspection fails, hows a good way to test to see if the wastegate is opening and closing?
boostin300
52
Las vegas
Test would be to see if your cars getting boost or not.. seems yours isn't.. lol. If you have an open dump tube, you could somehow test how much exhaust comes out of that, maybe if it was on jackstands? There would be a VERY significant amount coming out if it was stuck open at higher rpms
Make sure all the couplings are good, I did read a thread with a guy that had a similar problem, but he still boosted. His EBC was set at 21 pounds but it wouldn't boost past 12.. poor guy spent almost 500 in parts just to find a hole in a silicon coupler big enough to let out a decent portion of boost.
Check every last inch of your piping post-turbo, check for tiny cracks. Tiny cracks open up a lot more when under boost.. make really sure there aren't any. Make sure idle valve is also not stuck open..
If you know you have no air/vac/boost leaks after the turbo, it only makes sense the wastegate is stuck open because if there's exhaust coming out of the motor, which there is, that exhaust has to go somewhere.. if the gate's stuck open 100% for whatever reason you'll lose most of that energy that would normally spool up the turbo.
If it isn't that I wouldn't know what it would be. Could be something else but I wouldn't know what.
thevork
ShoarmaTeam Member
Can you test a wastegate by using an air compressor maybe ?
otherwise put it on a dyno somewhere and see what your engine does under load?
Just to rule out your boost controller, did you try to run the wastegate just on spring pressure ?
MA70Snowman
374
San Diego
MA70Snowman;1380514 said:
That's something I haven't tried will try that tonight
Well did two things tonight.
1) disconnected the boost controller from the setup
2) checked for leaks: I found one vacuum line leaking that went to the actual control unit of the profec B spec II, so fixed that.
Ran the Car w/o the boost controller and verified no leaks.
Managed to boost to 10 PSI.
however I am noticing something new.. although the BOV is working. I can hear the "Flutter" of back spool, or compressor surge. now thats got me wondering. WHY would the compressor surge, if the BOV is indeed working? its a HKS SSQV that i've been running for approx 3 years now. any thoughts on that one?
so figured out the wastegate problem, now I just need to fine tune the MAFT setup, and figure where this surge is comming from.
gaboonviper85
3,236
Northeast Philly
Everyone I know personally who has the hks ssqv all get that flutter under lower boost....when they really get on it, it let's out a nice solid sounding purge...I don't think you're hearing surge, I think it's just the valve fluttering in the bov.
thevork
ShoarmaTeam Member
My SSQ is also making a noise that is similar to surge but it sure is the BOV. You really really sure it's the
Anyway, do you have the new type SSQ without the ajustment screw?
If not, ajust (loosen) the screw some.
MA70Snowman
374
San Diego
like i've said i've had that SSQ for 3 years and never heard that come from the BOV before. and yes it is the "newer" one w/o the adjustment screw.
Highlex
61
Manitoba
Your SSQV will flutter from 0psi to around 2psi, anything more it pretty much blows it all off. I learnt this from my 7m setup but perhaps your is differant. Remember to get vacuum from a POST-throttle flapper source. Like off the intake mani, not off the throttle body.
(that was my problem anyways, I had it coming off the throttle body not the intake mani)
MA70Snowman
374
San Diego
boostin300;1381241 said:
Might want to look into the Synapse bov. HKS is good but doesn't let air out as fast as the Synapse.
Thats honestly what I was thinking. That the BOV isn't getting air out fast enough. but i mean. I was pretty sure that was the reason for the SSQV was to release preassure faster. and besides. I'm only at 10 psi at the moment. Less then I was before w/ no compressor surge. So reasoning would tell me that it should be able to get out the same amount of air just as quick. now if i was upwards of 16-22 psi. I'd be more inclined to thing that it was the BOV.
The port its tapped into IS indeed comming off of the manifold. so don't know about that issue. But yes i was aware of the flutter from 0 -2 psi.
I've driven this car w/o a BOV installed before, (was having my new pipes fabbed and welded. and When I would hit 2-3 psi I would get compressor surge. So i know what it sounds like, and this is the EXACT same sound.
I don't want to buy a new BOV unless i need to and i'm pretty sure the SSQV is rated for MUCH higher then 10psi
::EDIT:: now that I think about it. I don't think the issue here is "PSI" but more of a "CFM" related issue. any thoughts/agree/disagree?
rocketguy13
70
dallas texas
you should try running solid lines to your bov and just have short rubber lines between the manifold and hardline and hardline and bov. if you think about it the less flex you have in the bov control hose the quicker it will respond to boost and vacuum. making the line as short as possible helps also. i am running a tial and i had a long silicon hose that would implode before it would open the bov so i got some steel brake line and bent it to fit and now i dont have any surge.
MA70Snowman
374
San Diego
I thought the same thing, before and me and a buddy checked that.
I pulled the line off while he pulled it up to 3000 RPMS. and vacuum was consistant the whole time. I think max vac I pulled was -30. I got some quality thick walled hose from LIPP for ALL of my lines through out the engine.
grimreaper
2,180
Dallas
impossible ;)
jdub
Feb 10, 2006
10,730
Valley of the Sun
From one of my posts a few months ago ;)
jdub;1309332 said:
Not trying to be smart, but the physics doesn't add up. Science lesson follows:
- Std atmospheric pressure at sea level is 29.92 in/hg...yes it varies, but for this we need apples = apples.
- Vacuum is a reduction in pressure to the point where it equals zero.
- A perfect vacuum results (pretty much only in space)...this would be expressed as vacuum = -29.92 in/hg
- On a vacuum gauge, it would read ~30
- It is not possible to go less than zero where gas pressure is concerned...how can you take anything else away from nothing?
What you are saying is your motor is pulling a near perfect vacuum (29 in/hg). I'm not sure how you have the electronics/gauge hooked up or calibrated, but you can see how both of us would say that's impossible
Grim is correct, it's impossible.
boostin300
52
Las vegas
He's right, but your gauge can show 30 for various reasons, although it isn't actually 30 in the engine.
As far as the BOV goes OP, SSQVs can go bad. Although it wouldn't make sense since you didn't change anything on it while adjusting your boost. The SSQV has been used for very high horsepower cars and should support yours fine.
Even if your SSQV was in perfect working condition, I would still recommend you get the Synapse as it works great.
This vid is great explaining all this.
http://www.youtube.com/watch?v=MU5Y6d9rh1k&feature=channel_page
MA70Snowman
374
San Diego
lol okay just to get the two science majors off my back. I did indeed put two disclaimers in there. those being.. "I think" and "max". maybe a poor choice of a "max number" however the # wasn't important as was the result of the test. the silicone hose did NOT collapse.
btw thanks for the science lesson.
MA70Snowman
374
San Diego
Btw, that was an AWSOME video. showed the features of the Synapse VERY well. and made me actually understand where the faults were in the SSQV. its a shame it made such a good point, because i really was a fan of my SSQV. now when I do things I usually do them for performance or because it'll benifit the engine one way or another. I don't usually give into the "nice" things or the "pretty/cool" things. however I did LOVE the sound of the SSQV, and that is the ONLY thing i'm turned off about on the synapse. but logic is there. maybe sometime in near future that'll be my upgrade. But i'm really going to try and sort this issue out w/o replacing the BOV (barring that it is not broken) I'll try and get a sound recording of the noise maybe sunday. and post that up. maybe can get some actual diagnostics. who knows. ::crosses fingers:: it might NOT be comp surge.
