BoostedFloto said:JAKE: PLEASE LOCK THIS THREAD UP I'M TIRED OF THIS BS IT DOESN'T NEED TO BE HERE
jdub;984227 said:I'm not Jake, but you are absolutely correct...this kind of BS does not belong here. I cleaned the thread up. No more nut swinging, no more BS games. The bottom line is Bill spent a bunch of cash on a block that's not going to work. Basically a re-do...so for you central FL boys, if you got something to add that will HELP get Bill's motor up and running, feel free to post.
Any more of the BS and you'll be hearing from me.
Idealsupra;984331 said:Hey I didnt know you were here watching us when we put it together and installed it? Or when we were diagnosing engine noise? Or when it was removed? Where were you hiding?
chevyeater;984346 said:Just reading the thread and the clearly posted facts therein. Not intended as a personal jab as I don't know you or BoostedFloto from Adam. I just felt bad reading the thread and wanted to point out the ultimate cause for the car still not running so this can stop happening.
BoostedFloto;984379 said:JDUD or Jake or Other MOD..................Please just lock this thread it will never be just informative anymore.....TO much Drama in the Tampa MK3 crowd.....Makes me just want to get out of it all together.
Thanks
jdub;984393 said:Brian - these guys have been taking a lot of flack for what turned out to be a situation where they are going to essentially start from square one. I deleted a lot of the BS that was flying around this thread. Bill and Jayson are both frustrated...and rightfully so. Any help you can offer I'm sure will be appreciated![]()
chevyeater;984425 said:I can understand how they are defensive/defeatist at this point but, I'd like to see if we all can put bickering and partisanship aside help get this build back on track. I'd hate to see this end in a for sale thread. That is why I started posting here.
jdub;984436 said:I know
You nailed it...time to regroup and get this motor built!
jdub;984820 said:Jayson - You should not need another crank, unless the one Bill has is damaged.
Have the main/rod journals checked for surface finish and size and make sure it's straight/balanced.
jdub;984916 said:The 7M is a better crank IMO since it is fully counter weighted, it is heavier (hence the reduction in redline RPM), but is a smoother running crank. You can lighten it up quite a bit...the one I'm having work done on is getting abut 6-7 lbs taken off and knife edged. It's getting the usual straightening, journal sizing/polish, zero balance and a nitrite treatment too. All this tends to get a bit expensive
The problem is finding a good one...one out of a Cressida motor or NA Supra is best. Those have lived a bit more cushy life.
The 6M is fine, especially if you already have one that's had the work done on it to save the additional $$$'s at this point. I would still get it checked just to be sure based on what's already happened...call me a bit paranoid![]()
jdub;984960 said:Yeah...as you guys know, machine work adds up fast!
What kind of rods and was any machine work done on them?
