IJ.;1078481 said:What heat range plugs Scott?
sethron71;1078515 said:wait why would the shims be any different then? Did you try to shim the .01" out so you switched in different shims? I am confused...lol Have you put the timing light on all the plugs to make sure each one is firing? But if does start up and run, just with a horrible miss?
Seth
hottscennessey;1078718 said:They're 7's. I replaced them with new and the motor runs a little better but it's still missing.
I did a valve adjustment while the head/cams were out. The plugs are all firing, and it does start up and run. It just doesn't pull any vac. at all.
I started to measure the clearance of the shims and they seemed to be out of spec (good news). I can't be sure because the motor was still warm and the TSRM specifically says to measure when cold.
I'll take measurements tomorrow, just to be sure.
EDIT: lol.. looks like the valves are being held open because some fucktard did the math wrong and ordered their shims too thick![]()
hottscennessey;1079204 said:http://www.performanceautosport.com/
on the 19th they have an event:
http://www.vadriven.com/forums/showthread.php?t=244432
sethron71;1079640 said:Sweet,
Just joined....a chick drives that silver evo with pink graphics and a full cage? I hope she is hot!...lol
Seth
sethron71;1079775 said:Yea I did dammit!....lol
O well looks like a bunch of cool peeps!
Seth
group a supra;1080153 said:nice numbers sir
GeneStarWindGSW;1080155 said:about time scott. took you months to get 7XXhp but i knew you would.
gj bro
