IJ.;1033730 said:I'm one of his supporting Mods![]()
tturnpaw;1033633 said:what grind are the cams? isnt your cr like 8.9:1?
10secdream;1033671 said:Wow excellent numbers. What are your supporting mods?
suprahero;1034093 said:@what psi does your meth injection kick in? I was thinking of getting a kit for my 1.5 and have it kick in about 17psi. What do you think? I only plan on running 20psi of boost though. Thanks.
hottscennessey;1034077 said:very roughly 264's. Approx 8.9:1 is my estimation. I haven't taken exact measurements tho.
haha! What Ian said.
2JZGE
cams
870cc injectors
Stinger EMS
Bosch 044 fuel pump
Hg & ARP's
Sethron FFIM
Q45 TB
2.5" hotside IC pipes, 3" coldside
ebay 4" FMIC
XS Power manifold
knockoff wastegate
Master power T70 .68A/R
full 3" exhaust
Devilsown meth. injection kit
Os Giken quad disc cluth
Plugs : BKR7E's (6097) @ .026
I think it still has more in it.. I think I can hit that 700whp mark with a larger hotside, and a less restrictive exhaust. FWIW I'm happy with the car's power now and will be leaving the motor alone until I get an itch.
Looking at the dyno graph, I'm currious as to the drop in tq/hp in the upper RPM range, does anyone have any idea what would cause this?
gilberjj;1034270 said:great numbers, i loved my mp t-70 when i had it.
2JZGE
cams
870cc injectors
Stinger EMS
Bosch 044 fuel pump
Hg & ARP's
Sethron FFIM
Q45 TB
ebay 4" FMIC
XS Power manifold
knockoff wastegate
full 3" exhaust
hottscennessey;1078262 said:Yea man, I'll be there. Hit me up.
The supra has me stumped, it's getting spark and fuel.. that only leaves comression. I hope I just did my math wrong for the valve shims.
sethron71;1078443 said:Have you checked compression? Timing on the right side...lmao sorry had to ask! Why did you have to change the valve shimming? Same head right, same valves and cams right? Or were they wrong before?
Well let me know if you need a hand and I will come out and take you for a boost ride to lift the spirits...lol
Seth
