I had the misfortune of dropping a small bolt down the oil drain hole over by the last exhaust valve by #6. I didn't even know that hole was there! Anyway, this bolt made its way right down to the very rear of the oil pan, the little flat part just in front of the tranny. I thought I could fish it out through the drain plug but whenever I stick a wire in there it seems to hit a baffle right about where the sump area begins. Am I correct that there is a baffle there? The engine is in the car so taking the pan off is basically out of the question. I don't need the bolt so I figure it won't cause any harm there. It is a 8mm with a 13mm head and about an inch long, so it is pretty heavy and I think it will just sit there. I tried sticking a borescope down through the drain hole but it doesn't go straight down, there is something in the way, part of the casting I guess. Any thoughts?
Thanks
Thanks
