OK well this is sort of back on track! I picked up a new bottom end recently for about 150 bucks. 89+ reinforced block, hot tanked, cleaned, stock bore stock deck height. Unfortunately the crankshaft from this one is fubar as well because someone let it run with the crank pulley loose and not only did it mess up the keyway, but the snout is about 15 thousands smaller where the crank pulley rides...:aigo:
Anyways, I was originally planning for a simple hone and re- ring but i found a score in the number one cylinder that may be too deep, so i might be looking at going .020" over. Heres a picture of the block. I need some help on identifying this head gaskett hough. What brand is it? I measured it to be 1.2mm and want to sell it (spent hours cleaning it.)
Thanks! Wish me luck!
So far what i need/need to do
- Need new crank
- Toyota matched bearings
- .020" pistons
- Rings
- Machine work ( Check for cracks, bore, hone, deck head and block for MHG)
Thats the majority of it, but that is looking like a lot of money right now so it will be a slow process. I have most all of the gaskets and seals i need as well as all random bits and pieces.
