for your oil drain on the turbo, does it come out of the turbo, then do a 90 degree turn, then 180 degrees?
			IBoughtASupra;1662373 said:A few question,
Is your compressor housing on loosely, it look like that in the pictures? It is okay for now but remember to tighten it before starting the engine.
Is that a new waterpump? If not, why are you not using on? Get one from DriftMotion. I believe it is only 55 dollars.
You should paint the timing cover in aluminum. Clean and sand it just like you did with the other parts, prime it and then paint it with aluminum engine paint. You will like it like that.
Lastly, how come you didn't polish any of the thermostat housing parts? If you want to paint them, you still can. I did paint the whole thermostat section on the 7M with it bolted on the engine when it was on the stand.
Just clean it with a cloth soaked in gas or break cleaner, let it dry. Get some masking tape with newspaper and plastic, tape everything around it including wires and sensors, basically everything that will not be painted and then start painting.
It will look a lot nicer, trust me. Make sure to get high temperature aluminum and primer. Duplicolor Engine paint works very well.
hvyman;1662383 said:Smurf blue omg! The build seems seems to be doing ok.
Supra28;1662490 said:Engine is looking SA-WHEAT man!
Enraged;1662495 said:for your oil drain on the turbo, does it come out of the turbo, then do a 90 degree turn, then 180 degrees?
Enraged;1662540 said:it looks like it actually goes up a few degrees. i would suggest fixing it, you want a nice easy downhill path for the oil to drain, or you can kill your seals pretty quick. if the parts that came with the kit don't work, it means the kit is wrong. it looks like you have an ARZ oil drain adapter, you could always get it cut, extended, and re-welded to that you AN fitting clears the turbo.
IJ.;1662553 said:Won't "kill" the seals it'll just smoke like a bitch till it's corrected..
Enraged;1662760 said:i stand corrected. but its definetly easier to change it now with the motor on a stand, than in the car![]()
