Hey here is another update. Put the turbo on and the intake. As well as the oil pump. Sadly tho the ARP main studs were to big so i had to put in an old one to make the pump fit.
Also for those lookin at gettin the DM turbo kit. Be ready to take the turbo apart. Had to pull the exhaust housing off in order to mount it otherwise the bolts wouldn't go it. Then had to loosen the compressor housing in order to rotate the middle turbine section to get the oil drain to properly line up.
Other then that, enjoy!
Oil pump Brand new for DM
Here is a shot at the replaced ARP main stud with a stock one
Water pump, original
Oil pan on and painted
Head going on with ARP Studs
My turbo valve covers that i polished myself. Will be replacing them with some NA covers im cleaning up and polishing better than these.
---------- Post added at 09:16 PM ---------- Previous post was at 09:10 PM ----------
Getting the timing all lined up
Timed up! we think. gonna have a toyo mechanic stop by and check
Intake is on. Wish i had spent more time polishing it now...
Exhaust Manifold goin on
Turbo on!! Woot!!
wastegate
sooo puuurttty
---------- Post added at 09:19 PM ---------- Previous post was at 09:16 PM ----------
Next up is my fuel rail and injectors
I would like to thank Juhani for hand making these injectors for me. I am a proud first customer! They turned out great and i cant wait to test them in the real deal.
Here they are
In the Rail
mounted up!
thank a lot! input welcome!
---------- Post added at 09:21 PM ---------- Previous post was at 09:19 PM ----------
One last beautiful shot...mmmmmm so excited!!!!!!
