so over the last week , I have been building my repair panels and today I was able to get them burnt in , rears as well
now with the rockers repaired , I was able to get the cab height finalized @ 9" from the rockers to the Ground . + I also started on the cab mounts
Because there are only going to be 4 mounts instead of 6 , I wanted to make sure there were going to be strong .
cut out some 3/16" plate and surrounded it with some tube
Tacked into place I will add some more supports later , when I turn the frame over .
and cab side mount
Bent up some 1/2" solid stock with the 3/16" plate . as well as a "fish plate" for the cab side , 1/2" stock actually goes threw the fish plate for a stronger "plug" weld , and a toyota stock body mount bushing , I now have the front mounted
and now the front of the cab is mounted
still have some supports and final welding to do when I can turn over the frame , but for now it's good to go
also .. the cab now has it final "stance"
acetone can for referance
