My BPU'd 1jz swap/build thread....
rakkasan
Currahee!!
Fort Campbell, KY
Finally, I have the balance of parts I need. New shift fork (only because you can't order the pin & snap ring seperately :icon_conf ), snap rings & plate washers for the clutch assembly, throw out bearing, pilot bearing, et al...
I have the SPEC III installed & the lightend flywheel mocked in my freshly rebuilt tranny. I'm trying to get the hoist over today so I can get the motor off of the stand & mount the tranny. If I can, I should have the motor in tonight! :icon_bigg
suprastanger507mgte
2x88+2x89+1x91+2x92=ME
Hayward , Ca
Nice work. I bet you can't wait :). lol, neither can we to have one more 1jz to oogle at.. :):biglaugh:
Justin727 said:
GOOD! time to start throwing things together! Lookin good man, I can't wait to see it finished!! maybe after im done i'll look for an 90 to 1j
Hey Rakkasan. Looking good. I hope to get my clip in tomorrow, but who knows? I'm glad to see your swap is going pretty good. Hopefully between you and bobiseverywhere doing one right now, I should be able to get all the answers I need...................:biglaugh:
Can I take my aluminum flywheel and drill the holes out to match the bolt pattern of the 1jz and use it in my swap? I think I read it somewhere but I'm not sure. Thanks.
rakkasan
Currahee!!
Fort Campbell, KY
Thanks, I'll pass along any info I can if it's helpful...
Not really about sure about the flywheel. In my mind, I can't imagine a way it could work, but that's just my thoughts. Line it up & take a look, you might be able to...
Update on the intercooler. It turned out better than I could have hoped for. The bottom clearance is right on the money, the A/C is still intact & the stock 1J overflow bottle fits in the stock location too. I couldn't squeeze a 24x12x4" in any better.
I have a CAD dwg showing the mounting tab dimensions & locations. If I can find a way to print from Microstation to .tiff, I'll post the drawing up later....
EDIT: PDF of intercooler dimensions attached....
Idealsupra
Orlando
www.tampabaysupras.com
well looks like im being dragged into this.... my first act of executive order...
mark that spacer plate you have on top of the tranny in the one pic... throw it away.... im assuming thats the one from your auto tranny?
mk3forme
Lexington KY
ok Rak since you have messed with the AC already, what is needed from a 1JZ and what can be reused from the US setup. I mean can you the freon lines from the US 7m and does it hook up to the 1JZ compressor. I would appreciate the help as I have a basket case 1JZ unfinished install with no clip to compare to. The compressor didnt come with it so I have to get it already, but dont know what all is needed on top of that. Thanks
