Ok new shit, I started the wiring harness. Well first off I am swapping in a JZX90 harness and Ecu. It has been a pain in the ass. There are two missing plugs on the Ecu. Luckily there isn't much that they are used for they are most of the wire from the missing eb plugs which I will deal with later in the post. I split the Autosport harness and extended the stock harness
These are the pinouts that I am using from the Jzz30 auto ecu pinout
This is a breakdown of the Missing Eb1 and Eb2 plugs that are not found on the chaser harness. ( taken from 92teals site)
What my writing says is
EB2
Battery light on dash
40A fusible link
positive EFI relay signal
EB1
theft horn
this bigger picture of the Jzz30 pinout tells you were to wire in your makeshift eb plugs. Notice they are in the plugs that are missing from the factory harness.
I went to the pull a part and grabbed this from a Cressida.I am going to merge this in to the factory harness at the TPS location to replace the EB plugs
I am still trying to figure this one
The operating room. a closet door on some saw horses
Still have to deal with these . I think they are right????
Another sourced plug. This is for my Aftermarket Water temp gauge. I went ahead and just ran all the wire for my gauges along with the stock stuff so it is nice and clean. I also made everything removable.
And yes a 2JZge power steering pump will work on a 1j. You need to remove the stock reservoir and get the union for the supply hose ( part # 44337-24020 ) the o ring ( 90301-11016) the reservoir ( 44360-24042) and the hose ( 44348-24040)
still sitting
Oh I forgot my donor harness I am using mostly stock wires in the stock locations for future ease
