Ok today was my day off:icon_biggso I got at the wiring some more and pretty much have it all done, there is still one thing I'm confused about and need to figure out which I will note at the bottom of this post w/ pics.
First thing I wired was the IG1 connector as it was the easiest to get to on the 7M chassis(right in front)....Everything was color for color the only difference was the female connector wire for the CEL on the JZ plug was grey/red and not grey/green other then that it was straight forward, cut/splice and connect..
Double checked wire colors and location with the male side on the harness..everything is good(note there are a good amount of left over wires from the jz plug)..
The next connector I did was the square IH1 connector and again everything was pretty much color for color I think there was one slight difference but I can't remember now off the top of my head..
So 2 down 1 to go..and this is the one that confuses me, this connector IH2 is the TEMS/ABS/AC connector I don't have TEMS or AC so that doesn't concern me but I do have ABS and with no B3 connector I can't figure out how to wire it in.
There is one more connector on the 7M chassis harness but it is 3 pin and the wire colors seem to match up with what I need for the ABS but I'm one wire short according to the schematic(there are 4?)..
Left over 3 wire 7M connector...
JZ connector that's left over..
^Help would be great but other then that my wiring is pretty much complete, I hope it's all right but it seemed too easy
