MKIV wheel tire sizes
TRACKMKIII
464
Atlanta,GA
I finally have a set of MKIV wheels on the way so I want to order tires soon so they will be here when the wheels show. I just want to know what is the widest tire size that will fit on the wheels front and rear. A friend of mine told me he thought that a 305 width would fit in the rear but I have my doubts. I think a 245/40/17 would be about the limit in the front but I am not sure bout the rear. I searched around but I can't seem to find the info about the tire size but there is plenty of info about the wheel fitment. Also if you have pictures of the different tire sizes on the wheel that would be great too. Thanks
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
I have 235s on the front and 275s on the back. Although you can run much wider tires on both the front and rear. But what I've found is there a huge price difference after 275s, for say a 275 would be $140 for a specific tire and a 285 in the same tire is $50 more expensive. But I have seen 315s on MKiVs before.
TRACKMKIII
464
Atlanta,GA
Do you have close up pictures of the wheel and tire combo?
shaeff
Kurt is FTMFW x2!!!!
10
Around
I run 275/40/r17 rear, 255/40/r17 front Falken Azenis rt-615's. Slight rubbing on full lock, but that was cured by adjusting the bump stops. ;)
GotBoost?
I do
Nov 25, 2005
318
By My Computer
Rears: I've heard of 275's in the back, while the wheel is on a mkiv chassis. But I don't think you can go with anything wider than 255 on the mkiii (rear) chassis, on mkiv TT wheels. In my personal experiennce, there's not enough clearance with the rear shocks for anything wider than 255, unless you use an adapter, which many people don't recommend. Remember, if you're after more grip and performance, (a lot) bigger is not necessarily better.
SilverSupraT
7M '78 Toyota Pickup
Oct 3, 2005
556
Eastern WA
www.geocities.com
I have 235/45's on the front and 275/40s on the rear and they fit really well. Like Fletch said, prices start to go up pretty fast once you go bigger. I wouldn't want to go much wider than 255's in the front and 305's in the rear IF I wanted them to be as big as possible.
TRACKMKIII
464
Atlanta,GA
A 305 in the rear would be sick!! I think the MKIII looks great with a really wide tire!! Does anyone have pics of a 305 in the rear?
shaeff
10
Around
I have absolutely no issues with my 275's out back, and I'm lowered on Eibachs, and no spacers.
SilverSupraT
Oct 3, 2005
556
Eastern WA
www.geocities.com
Ah yeah, forgot to say, I'm on Tien coilovers. I can't lower them too far, not because they hit the inside of the fender, but because they will rub on the spring/adjusting nut/jam nut because the camber is so far off. With a spacer I could probably handle 295s after rolling the fender while keeping my current height adjustment.
suprajjang
Supra Enthusiast
VA
I think you can fit 275 easily. I currently have 255 on my mkiv rims and the tires are too narrow for the rims. Im going with 275 on my next set.
annoyingrob
Boosted member
Jul 5, 2006
2,304
Calgary, Alberta, Canada
285/40 in the back, 255/45 in the front
Supra&
You can't go much larger in the back than this. 295, MAYBE 305, but on a 9.5" wheel, you're really not increasing your contact patch any.
As for the front, 255 is really about the limit of what I would run on the 8" wheel. My turning radius sucks now due to rubbing ;)
just for reference, I forgot I had this picture on my server, 255s on MKIII 5 spokes:
He's on this site, but I'm not mentioning names ;)
rs4rush
701
Kirkland, Wa
Fail...
I ran 275's in the rear no problem.
Nalleywhacker
Formerly gnarkill87
Oct 2, 2006
643
chattanooga,TN
on my old 91, i had 275's on the rear with eibachs and it wore groves in the strut caseing didnt hurt anything but theres not way i could have gone any wider.
TRACKMKIII
464
Atlanta,GA
noah89t;988828 said:
305's on the rear do fit.
my mkiv wheels have stock fronts at 235 and rears are 275/40, lowered tokico shocks and springs, no spacers.
To fit the 305's on there would I have to use spacers or roll the fenders?
mrsuprafreak
Where does it end?
Aug 14, 2005
267
Orlando
I have 235/45-17F and 275/40-17R on H&R and Tokicos with no problems. I choose the 45 series in the front to try to give it a little height because I knew the H&R's would be dropping the front way down.
blackout_89t
King of the roll
Apr 25, 2005
488
Toronto
All tires are slightly different so determne what brand and model tire you want and then check on the manufactures website for recomended size limitations. The tires I have on the MK4TT rears specify not to go any wider than 275 on a 9.5" wheel.
