I'm in the middle of installing an AEM water/methanol kit, and it says you can place the nozzle farther away from the throttle and manifold for an "enhanced cooling effect". I will likely install the nozzle into my HKS 3000 pipe right after the blow off valve(to avoid spraying mist out of the BOV), but I was just curious to hear some opinions about placing the nozzle farther away to allow the spray to cool the air better before it enters the engine. Is this effective? Or does water/meth do all of its cooling during the compression stroke?
Also, I plan to run around 20psi on 92-94 octane pump gas. Considering that it is already pretty safe at 15psi, should I opt to run a small to medium sized nozzle? I estimate to hit around 450+hp. The kit comes with 3 nozzles:
small 130ml/min 150-250hp
med 315ml/min 250-400hp
large 550ml/min 400-650hp
