making a lhd supra rhd (slightly NWS)
hks_trinidad
nyc
hey guys i was just wondering what it would take to convert a lhd supra to rhd i know theres no advantages to it but i was just curious as to how one would go about doing a swap like that? would you need a front clip or just harness and dash? thanks
whudafux
Formerly dcrusupra
Jan 5, 2006
1,034
Cullowhee, NC
Cut your old fire wall out, put the RHD one in, swap the steering racks, flip the body harness and switch the door harnesses, put the RHD dash in, and put the steering wheel back in.
IJ. said:
Why on earth would you bother?
To be more like you? :dunno:
That being said, I'm doing it to mine. Lol. Only reason is because I got the clip for free and the swap done for an incredible discount, probably free also. :evil2:
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
in the end itd probably look better and be safer if you just bought a rhd to begin with.
SupraChrisMk3
New Booster
Feb 8, 2006
170
Salisbury, Vermont, United States
Really. Unless you are just trying to make it look like it's a real JDM supra. Which in itself really isn't much of a reason. I just think that it is way to much trouble if all you're trying to do is make the car appear JDM. Not trying to be to harsh or anything but I just don't see the point, but whatever.
werewolves182
is without a supra :(
Aug 23, 2005
436
Crownsville, MD
Honestly I dont see it being terribly complicated. As long as you get an empty RHD clip (without engine and trans) and you are a decent welder it shouldnt be too bad. The RHD clip gives you everything you need. Its basicly just pulling the motor and interior, cutting and welding the RHD firewall in and swapping over all the RHD parts.
I personally have always wanted to do it.
WHY?
Evilempire1.3JZ-GTE
SF what a waste of supras
Jun 22, 2006
1,382
SoCal
Dont forget you have to swap the upper firewall also under the window so your wippers work right.
Also a RHD MKIII is verry cheap to begin with id just buy the whole car for 5-7000 then switch the parts the redefines the cars identification this is legal if you own both cars! just tell them you repainted it & changed the fire wall/parts DMV will accept it if proven and can provide evidence or paper work. They will use the special rivets for it also.
phoenix6
Rockin' the blades
Aug 13, 2006
1,138
Serena's Place ;)
I personally wanted to do this bc of one, the inability to afford a rhd vehicle and two its not to look JDM to me, its more or less something I think Id like better and a little more unique here stateside. Thats just me though, some people think its stupid but I think itd be a fun project.
Dec 3, 2003
6,653
Canada
Just buy a RHD Supra and be done with it.
Duane
