Ok Adam,
Here goes.
I am running the typical MAFT, 3" MAF, AVC-R, S-AFC II combo. It runs great.
With full fuel control from MAFT-pro, the TCCS is still trying to make the car run stoich under closed loop, "read most of the time." Does the MAFT pro have the capability to send the TCCS a fake o2 signal to trick the ecu into not constantly playing with the fuel curve?
If we could clamp the narrow band lambda, then TCCS ecu would be in open loop mode, and would let the MAFT-pro do what it wants.
How's that intake manifold doing?
I'm in school persueing my ME degree at the moment, but eventually I'll buy this product, for now, I'm still pushing the MAFT for those that don't need the extra features. I wish I had waited, but I didn't so now I'm stuck with the second best piggy back. No harm done.
I think you called the EMS a piece of junk... explain.. now.
drjonez said:
Note that personally I use the AEM EMS….too bad it’s a piece of junk.
Anyway, I think that is the only thing I see that is a conflict. Highway cruising and part throttle is nearly impossible to tune, because the TCCS just sits there playing with the fuel. If the TCCS thought that fuel was stoich at all times, then, with a wideband and EGT, one could bend the TCCS to their will.
Just my $.0089
