MAFT-Pro Tuning Thread Unofficial and Uncensored
turbobob
196
Near Detroit
3rdtimearound said:
Hey Bob,
Does the tune response tuning page settings have any bearing on the idle characteristics what so ever? It only gives input on a from "idle tip in", right?
Wayne
The Response page is supposed to be for tip-in, step-in,.... etc.
Those with choppy cams may get some MAP enrichment at idle which is not good. Plus if the car starts to idle poorly, the MAP enrichment can trigger and make it worse.... So there is a MAP TPSmin and MAP RPMmin to shut off the MAP enrichment at idle.
But, the answer to your question is "yes" :) (excellent question)
:drink1:
malloynx
NC
i had the same timing problem as well. worked for a bit, then tried to dial it in and it went crazy..
we need to find a car in the detroit so bob can get his hands on it..
i'm going to make a fresh thread in reguards to a donor car
Supra
304
Rockford, IL
turbobob said:
Leave the load source at "Use MAP" unless you have the patience to re-work the VE table. That option is for those odd cars with really radical cams that can't get a decent tune using the standard speed density algorithm.
Thanks for adding to the thread. I chatted with "3rdtime" last night and MAP/TPS load was the only thing that seemed possibly out of wack. When he said his car dropped to 14.7 @ idle, i thought we were headed in the right direction. I uploaded 4.65 to my 87T last night so that I could 'see' the new settings but I'm waiting on my turbo to come back so can't give any feedback yet. :icon_conf
In the case of "3rdtime"'s car, if he switches from MAP to TPS based load and his fuel mixture leaned out to the correct idle mix, is that an indicator of anything? Should we persue a TPS based load and a new VE table?
Again, wish my car was running so I could play too but it's not....:icon_conf
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Hey Rich, I thought we were on to something too. I appreciate your help as well as everyone else's. I think we will get somewhere with this thing sooner than later now that we are getting some help and will be pursueing a mkIII to go to Bob's place for tuning.
Wayne
supralover2000
12.8 and dropping..
Apr 4, 2005
132
Long Island, NY
www.mk3.us
Bob,
I understand that you have a lot of work ahead of you with some of the new changes to the software, but at this point, with some of the new changes already achieved, I feel we need a new Quick Start Up sheet. The last one I have is for software version 4.4, and at this point we have a handfull of people attempting to run version 4.6X. We don't neccesarily need a whole new manual, but rather a supplement of sorts that clarifies and explains the new changes.
Note: I still believe that many people are just diving right in to this without having read enough nor understanding exactly what they are doing. Unfortunately there are probably many who's base (initial condition of their vehicle) might not be as solid as they believe and this leads to assumptions that the Maftpro is what causing the problem... Nonetheless, a new write up should help get everyone focused on addressing the proper settings rather just changing things "for the heck of it", without real knowledge of what that change will bring.
chriso
Supranian
Bay Area, CA
AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh:runaway: :runaway::rant2: :cry::wuteva::dunno: :madfawk: :madfawk: :wtf: :wtf: :wtf: :wtf: :wtf: :eek:wned::rant: ::dead horse:: ::dead horse::
Here is my idle now......
turbobob
196
Near Detroit
supralover2000 said:
Bob,
I am completing the testing of 4.80 (basically 4.65 with some loose ends cleaned up) I will be updating the manual, and the tunerpro files.
On my car (Ok, a stealth) the idle is dead steady, no tip in issues, and it drives really nice.
So, like many speed density systems, there is more tuning required to get things right. I am still looking for a Michigan guy to work with. Dr Jones puked a turbo and is out of action until he can get it fixed.
I am out of town (hotel room) but hope to get to look at Chriso's stuff. It should not be that hard to stabilize the idle with some tuning. (your MAP sensor vacuum hose isn't sucking shut is it? I use fuel-line hose on mine
(or the really thick-walled vaccuum hose when I can find it.) Make sure you are not trying to use the PT tracking with the stock O2 sensor connected to the ECU.
Bob
chriso
Supranian
Bay Area, CA
suprastanger507mgte said:
After reading that post above with whatever is burning in that fire, Kyle, I'd stay away from Chris lol.You may be next.
Chris, any progress on that MAFTPRO?
:bigun2:Does this answer your question?
bigaaron
4,692
Pomona, CA
www.driftmotion.com
We just got a customers car with a maft pro running today with a brand new 7m engine (literally a brand new shortblock). It started right up and ran ok. The ZT-2 shows the afr is between 14.3 and 15.1, but the afr on the maft pro is reading between 10.3 and 9.2! It's not at 10:1 or it would be smoking like a sob at idle and it is not. I selected the afr input as 5 for the ZT-2, but I tried everything from 1 through 9 and none of them read correctly. I honestly didn't have a chance to check the connections yet because it was late, but if the wiring checks out ok then what could cause this?
Also, I need to give him his car back using the best possible software version available NOW, what would that be? I don't like 4.40, and I don't like 4.67. It's not my car where I can baby it and watch it every second. What is the best version to use? We are also going to dyno tune it after about 500 miles with no/minimum boost, and at $160 an hour on a dyna pack I can't afford to loose his money by changing the software afterwards, considering the afr seems to vary widely after software upgrades, even with the same exact settings.
chriso
Supranian
Bay Area, CA
Aaron, I hope your not asking me.....lolololololol
drjonez
the motor city
www.4cefed.com
your grounds are not common. connect the MAFT pro's purple wire to the ZT-2's ground.
any reasons you don't like any of those? 4.65 is your best bet in my book....
CPT Furious
Now MAJ FURY!
KDOV
I read about a lot of these problems, but I am running 4.65 right now and it idles and runs perfect! Haven't boosted past 10 psi yet, but the car is running strong. I like it...
chriso
Supranian
Bay Area, CA
Would you mind sharing your settings??
