MAFT-Pro Tuning Thread Unofficial and Uncensored
malloynx
NC
how much timing are you seeing? i was seeing 22 of advance with race gas... i wanna knock it down to about 20
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I had 13.5 adv @ 21psi / 5500 rpm, I havent touched timing control as I am clueless and dont want to f@ck it all up. I dont really know what I should have where as far as timing advance, and I can find very little info.
chriso
Supranian
Bay Area, CA
jtamulis said:
Um, I think there are some wires that HAVE to be cut for proper install, can I
get a checkup from someone who has installed?
Jeff
No wires cut if you are running speed density mode (like me). If you are running through a MAF or using a SAFC there may be other wiring instructions.
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Well Chris, you and I are not alone in this tuning circle-jerk. Still haven't plugged mine in since I have talk to you. Change stuff in the pro and it still runs way to rich, all hell, you know the story. I'll be waiting in the wings for some solutions.
Call ya later,
Wayne
malloynx
NC
yea, my car idles like it's a cammed big block and now it will die sometimes when i come to a stop and press the clutch in.
this is very fustrating
supralover2000
12.8 and dropping..
Apr 4, 2005
132
Long Island, NY
www.mk3.us
Chriso:
if you look at your initial settings, you will see Freq OUT Mode (wish gives you the option for supra... then you will see Freq In Mode which gives you the option for "0: no Maf connected". Please look over your settings and tell me if you see this?
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
I'm posting up my settings here, of course my setup is different, so......
I have dual walbros, -8 line, afpr @32, 680cc injectors, ar3923's @ .027, ported/polished head, 1mm o/s valves, hks long runner, t-61, big I/C, built auto, 32-3400 stall, q45 (the diff here is my tps reads .41- 4.9x v)
veh sel -0
#cyl-6
disp-3.0
airfl mode- speed density
map source- gm 3bar
load srce- use map
baro mode- sea level;
f-out- supra mkIII
v out 1- use setpoint
v-out 2- use setpoint
afr srce- dynojet
f-in mode- 20 (for timing monitor) Chriso you should do this!
aux1 mode- trig off
setup:
mainscale- -23.0
v-out 1- 2.5
v-out2- 3.6
after start 2.2
lo load pt- 36.4
mid load- 100.1
hi load- 143
f out max- 0
fe smoooth- 30
use ve table #1
spk base- 15.0
tm base- 1.9
tm correct- 1.27
af tr delay- 0.0
boost control:
tps spool-1.90
rpm spool-2494
tps start- 2.50
psi start- 16.0
dc% start- 55.2
psi set-20
psi aux-22
gain- 10
dc% aux-50
afr tracking
Min TPS 2.50
Min RPM 2400
Min MAP 166.4
Lean Lim% 17.5
Rich Lim% 25.0
Gain 5.2
AFR2000R 13.6
AFR3000R 12.5
AFR4000R 11.5
AFR5000R 11.5
AFR6000R 11.5
AFR7000R 11.5
AFR8000R 11.5
Aux % 0.0
Air Temp
-40.00 0.0%
13.00 0.0%
41.00 0.0%
62.00 0.0%
82.00 0.0%
103.00 0.0%
129.00 0.0%
173.00 0.0%
212.00 0.0%
Aux Triggered
All 0.0%
Tuning
RPM High Mid Low
400 0.0 0.0 0.0
800 0.0 +14.0 +15.0
1200 0.0 +15.0 +10.0
1600 0.0 +10.0 +5.0
2200 +5.0 +10.0 +5.0
2800 +5.0 +10.0 0.0
3400 +3.0 +10.0 0.0
4000 0.0 +10.0 0.0
4600 0.0 +10.0 0.0
5200 0.0 +10.0 0.0
5800 0.0 0.0 0.0
6400 0.0 0.0 0.0
7000 0.0 0.0 0.0
7600 0.0 0.0 0.0
Tune Response
TPS Enrich 0.40
TPS Delay 0.60
TPS Size 6
TPS MAP Max 104.0
MAP Enrich 0.1
Boost Enrich 0.1
MAP TPS Min 0.800
MAP RPM Min 2560
MAF Limit TPS Threshold 0.00
MAF Limit 0.00
MAF Limit/KRPM 0.00
Timing Monitor
Spark WOT Spark Aux
2000
2500
3000
3500 all at 15.0
4000
4500
5000
5500
6000
6500
7000
7500
8000
PT Tracking - not using but this is what I tried
Idle TPS .44
Idle RPM 1088
Idle A/F 13.9
Cruise TPS 1.90
Cruise RPM 2208
Cruise MAP 91.0
Cruise A/F 14.5
Lean Delay 5.0
Gain 5.0
Lean A/F 15.0
I am running and idling and cruising fine, not much to complain about other than boost creep, which Mike has had the same prob and gave up on the boost control. I think it may have to do with the gain, when I get time I will tweak some more. I hold real close to 11.5 at wot in 1/4 mile, it creeps a little leaner at 6000+ so I will richen that up. My main issues I had were b/c which I am almost good now, The throttle response used to suck ass, but its great now with 4.65, I havent used timing control, and wont til i see what other people do and whats safe. I occasionally hit fuel cut under certain conditions, passing on highway mostly, never in a straight 1/4 mile pull. I do get a little lean idle miss under hotter conditions in closed loop when a/f is leaner than ~ 14.5. I dont believe thats a maft pro issue, it did it b4, but Id like to tune it out, even though it wont hurt any thing. I will post this in your FAQ thread also Mike. These settings would not benefit someone to copy unless the same setup, but at least we can look at each others and say "hey, why do you have that , what did it do for you". Start helping each other out, I have been frustrated at times I admit, but I still love it.
malloynx
NC
thanks.. i'm loosing my mind over here. also for some reason i put the car a 2.96 for liters and it seems to run a bit better.
techincal our motor is not a 3.0l
chriso
Supranian
Bay Area, CA
Exactly !!!!! Thank God !!! I have been trying to get some of us guys running this to compare our settings for over a month so we can get some of the common issues ironed out. And, Yes, I know we all have slightly different setups and the settings will reflect that but at least we can see a rhyme or reason for them. Thanks so much guys for all the help. I am finally getting somewhere with mine. I went out last night and did some highway pulls with some of the setting changes that you guys recommended and I was impressed with the performance. (Maybe I won't flush $600 down the toilet). Anyway, I will post some logs later on today since I still have a lot of adjusting to do but at least it looks like I am finally getting somewhere.
Tookwik, I still notice a wicked miss around the 2500RPM mark (but it is not consistent) and I noticed a lot of threads regarding that issue lately but not all guys having it are running the Pro.
Supralover, I will check my settings today that you are recommending.
You guys are awesome.
chriso
Supranian
Bay Area, CA
Yes, you are correct Mike, When you say "run better", in what way do you mean?
tookwik4u89
Red T-shirt
Apr 6, 2005
2,008
Rockford, IL
ya, i think those settings are just for response, maybe i can use that for fattening up my idle, and maybe t/b size since i hve the q45?
edit...my bad, disp is not in throttle response!
chriso
Supranian
Bay Area, CA
malloynx said:
is your 32psi psi static ??
Static?
My fp is set at 34 running (idle). I set it higher according to the TSRM (jumpers on with engine off - iirc) to somewhere around 38 I think. It seems to be holding steady. I have a Megan Racing AFPR which seems to be working fine but will eventually go with an Aeromotive when the funds allow.
malloynx
NC
chris... with engine running. pull vac line off, cap it, set your "STATIC" fp, put vac line back on
