M3- Project JDM Euro!
shaeff
Kurt is FTMFW x2!!!!
11
Around
It's very clean overall, but there's some body damage on the rear driver's side fenderwell. I'm getting it repaired before I even start driving it around. Thanks! :)
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Dang I had a list of common issues listed out but it didn't post.. but here we go again.. I should have posted this before you put money down but I just realized that now.
Rear shock tower cracking- section needs to be cut out and a new tower welded in
radio head set back light going out- just need to open it up and re solder in a week contact of a resister.
Cluster black light goes out - just need to pull the cluster off and change the bulb.
If your ABS light it might be a brake sensor and my dad figured out a way to fix it and save over $100 :)
I know there is more but that is all I can think of right now
shaeff
11
Around
That's alright. I actually ended up buying it today. If all goes well, I pick it up tomorrow night.
That shock tower issue bothers me! I really need to check mine now. :( Those other issues aren't really anything much, though. I'm not sure how long I'll keep the stock stereo- it doesn't sound that great. ;)
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Yeah. I think when my dad bought the car it was still fine but he ended up taking it to a shop to be taken care of and reinforced just in case.. I think it cost $600 in the end.
shaeff
11
Around
That's not bad at all. I'll have to check mine on Friday when it's light out. Can you see it from inside the fenderwell, or do you have to pull the trunk carpet to see?
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Not sure if you can see if from the outside. But we took the rear carpet out to take a look. I don't remember what to look for though.
Brewster
So it goes.
Apr 15, 2005
1,156
Morgantown, WV
Plus:
Exploding engine fan
Exploding radiator
Self destructing water pump
Wiring harness that runs to the trunk cracks and shorts out
:biglaugh:
Isphius
Supra-less :(
May 30, 2006
359
long branch
I went to test drive a 3.0 liter m3*only one year i believe) and it was a super nice car interior wise and ride and handling but the power didnt impress me. It felt like it had less torque than my NA supra that i was driving at the time. But cranking the rpms way up and spinning into 2nd gear is fun too. It had a dinan exhaust and it sounded very good. I would just get the 3.2 liter one maybe it has a little more torque.
I was looking at a 325 today at the dyno shop......
WOW talk about "limited engine access" :nono:
It looks like it's based on a 4 cyl chassis that they've recessed the lower firewall in to fit the 6 cyl engine in there.
Zumtizzle
Can't Wait to Be King.
Oct 21, 2006
2,825
Sac-Town, NorCal
-Rear shock mount failure is a very common problem, and can occur in as little as 20k miles. The symptoms begin with a dull clunking noise in the rear over bumps or rough roads, indicating that the shock piston rod has separated from the bushing mount. This can progress into metallic noises as the mount bolts shear off if not replaced in a timely fashion. The broken mounts eventually damage and tear the rear shock towers. Stronger E46 mounts along with Z3 reinforcement plates are recommended for replacement, and even better aftermarket parts are available from outfits such as Rogue Engineering and Ground Control.
http://www.unitedbimmer.com/kb-e36-common-faults-faq.php
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Oh yeah I forgot about that one.. Good thing is.. to change out the mounts take like 10 min per side. Half the time is taking off the wheel and putting it back on lol.
relax
75
san diego
Hmmm, I have never tried to drift my e36 m3...How hard is it? I'll try it at my next autox. Any tips for a noob?
shaeff
11
Around
I've tried sliding around a few corners. It's not too bad. :) Though, from what I've read, my '95 has a more "driver" oriented stock suspension setup compared to the '96+ M3's.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
TurboFreak;1112630 said:
Lookin good Boris.
So did you clean the numbers off the side of the M3 before your parents saw?
haha. All the dust all over the car didn't help though.
The E36 is a great platform for drifting and gripping. As for tips... I don't really have any I just go out and have a blast and learn from mistakes that I make.
I have bilstein and eibachs so mine is probably better then stock :biglaugh:
If I start doing more track days I probably going to get some coilovers though. But then again it is good as is.
