BorHor;1247944 said:Pimp out the bimmer.. or get another supra.. Pimp out the bimmer or get another supra..
That is all that is running though my mind today. My dad told me I can keep the M3 if I want, that way I don't have to buy another car. But I feel so lonely at all the supra meets I go to
I could just go turbo or supercharger I guess....
I also started looking in to new headlights for my car and I think I am going to get the cheap DDM lights and do some sort of retro fit. (sorry Shaeff I am not as ballin as you are for cutting up ZKW's)
I also need to find a new pass side fog light because a rock or something cracked it about a month ago.
BorHor;1248132 said:I have been looking in to boosting and it seems like it is going to be a pain in the butt since I am OBD2. Looks like I have to wait a while.. Also I don't really feel like lowering the compression ratio on this motor just yet...
NashMan;1248186 said:i whould not bother dude there stuiped tight fit
trans\rear ends can't really take it clutch's are freaking stuiped money for the car
you jumping to an expencie life by turboing bmw's
i done some befor and m3 likes your's
blew his tranny and rear end and killed his clutch
BorHor;1091914 said:Dang I had a list of common issues listed out but it didn't post.. but here we go again.. I should have posted this before you put money down but I just realized that now.
Rear shock tower cracking- section needs to be cut out and a new tower welded in
radio head set back light going out- just need to open it up and re solder in a week contact of a resister.
Cluster black light goes out - just need to pull the cluster off and change the bulb.
If your ABS light it might be a brake sensor and my dad figured out a way to fix it and save over $100
I know there is more but that is all I can think of right now
Brewster;1092747 said:Plus:
Exploding engine fan
Exploding radiator
Self destructing water pump
Wiring harness that runs to the trunk cracks and shorts out
:biglaugh:
Zumtizzle;1093063 said:![]()
-Rear shock mount failure is a very common problem, and can occur in as little as 20k miles. The symptoms begin with a dull clunking noise in the rear over bumps or rough roads, indicating that the shock piston rod has separated from the bushing mount. This can progress into metallic noises as the mount bolts shear off if not replaced in a timely fashion. The broken mounts eventually damage and tear the rear shock towers. Stronger E46 mounts along with Z3 reinforcement plates are recommended for replacement, and even better aftermarket parts are available from outfits such as Rogue Engineering and Ground Control.
http://www.unitedbimmer.com/kb-e36-common-faults-faq.php
