LPPRO's 6 month 2jzge-t build now fuel cut equipped! lol
albert74
111
Florida
lppro;1067718 said:
wow you live close! i just graduated from deerfield high. and i live in deerfield right off of Hillsboro. i have some friends that live around you.
yeah i graduated from deerfield beach high as well but in 2003. I used to live off 44th st back then.
albert74
111
Florida
yeah, i used to alot a year ago, but i've been out of a supra for a while. i just got this one i got now, but i haven't figured out the my emanage ultimate yet. the car runs but it needs to be tuned and i can't get the EMU to start the car for anything. i might just throw in an afc and call it a day, but it's set up to lay down over 600rwhp.
albert74
111
Florida
nah it's drowning in fuel. i'm running 65lb injectors on a stock ecu so it can't control them. it's not driveable, do you know anyone with an safc?
albert74
111
Florida
IJ.;1068127 said:
This may be a radical concept but put some smaller injectors in till you can get the fuel control sorted.....
I might just have to do that. Maybe some low imp domestic 440's as i already have the clips and resistors wired in. We'll see, i might be getting an safc2 this weekend.
albert74
111
Florida
Won't run it again till i have some sort of fuel control on there. I finally got a laptop tonight to mess with the GEMU so i'll get on that tomorrow.
lppro
LP Performance & off road
Apr 21, 2007
895
Sugar Hill, Georgia, United States
so i drove it back from the shop today (40 miles) and the last few miles the temp started to creep up to right under 210. i was on the highway in 5th gear about 2500-3000rpm the whole way. dose'nt seem quite right to me...
so after i get home i park it and about 20 min later i go back to try to move it into the garage and nothing. it dose not turn over at all... and the battery is fine... fans turn on, fuel pump turns on... so i push start it and get it into the garage. a few hours later i go back to it and it starts right up...? i dont get it...
i remember the first night i when i brought it home over a year ago it did the same thing...
lppro
Apr 21, 2007
895
so i got it running better so i started to push it little harder and i couldn't figure out why it kept cutting out when it boosted past 12 psi (ish) then it hit me FUEL CUT! lol i never had this problem before... but sure enough i payed a little more attention and sure enough the CEL would come on when it cut out and fell on its face.
so how can i get rid of this?
the most boost i saw was 15 psi. and NO traction (= lol
