Lotus-born suspension on the MKIII Supra?
Typhoon
208
ACT
Yamaha have been on Toyota's payroll since the early 70's and probably before. Smart thing to do really, farm out what you suck at!
Regards, Andrew.
Figit090
Fastest mk3 GT4 1/4 mile!
Jan 7, 2006
1,835
Humboldt County
MKIII N00b said:
wikipedia told me that toyota were the ones who brought subaru back from falling. toyota was the one who gave subaru the technology to make the impreza.
what exactly did they do?
links to specific pages?
pogoism9
1UZ for me!
May 18, 2007
367
fredericksburg, va
bowsercake said:
2ZZ-GE, not FE. The F and G heads are of a different design. The M and JZ use the G type heads while the UZ engines use the F type heads. I think it has something to do with the cam angles.
Sorry, merely a typo. The F designation is what Toyota calls "economical" while the G has a more aggressive valve angle.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Ariel atoms use Honda motors because there cheap and perform. There more of a kit car so you could probably have one made to use anything, but default they use whats available and performs.
themadhatter
760
Vegas
the ecotec is the new 4 banger from gm it was built to replace the 2.2 and 2.4 they had been using for years in there cheaper cars. Beleave it or not there very good motors...for a gm you can get the motor turbo in th forum of the solstice gtp/sky redline or supercharged in the ss colbalt/ion redline i think its funny it took gm so long to design a good 4 banger lol
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
Eh the ecotech is unimpressive, its rated at something like 205 horsepower. Didnt the turbo MR2's from the early 90's make that much? hell the stock celica gts/elise 1.8 made 180-90hp all motor as said before lol
no, the ecotec is an AMAZING motor and strong as hell for what it is...
with 2 fairly simple mods it will take anything you want to throw at it...
one is the uniseat, which is a one piece valve seat fro both exhaust valves in each cylinder that is easy to replace and takes a ton more abuse.
the other is the unibolt. It's a large ass stud that goes from the head, all the way through the block to hold the mains in place.
just those options alone will make the engine nearly bomb proof (as proved by their drag cars). Did I mention they come with a main girdle stock?
And no, not compared to the honda... They put the same mods on both motors, and they're equally as powerful and quick... I want to think the ecotec was a LITTLE more powerful though, but I'd have to look it up, but the difference is marginal IIRC...
same with the ecotec, and that's the highest option level, they have lower power models...but it's still going to be wicked fast...
"At 307 pounds fully dressed, the L61 is the lightest engine GM has produced in its displacement class, and one of the most compact four-cylinders in the world. "
