I have been wanting to do this swap for a few years and finally decided to pull the trigger. I have been working on it for the past 6 months and here is my progress.
Here I am bringing her home 2 years ago. I had been looking for another supra for a couple years before and a friend of mine knew how much I missed my 91 so he gave me this 92.
She had been puled apart for paint and me and my friend spent 2 weekends putting her back together after being apart for 8 months.
I spent the first year just dealing with details. It was a pretty good running car but had a lot of little tuning issues. It was an automatic which was new as I have only owned one other auto supra and it was a mk4. Everything really needed to be R&R'd on the engine. I went back and forth trying to figure out what to do and kept coming back to the LSx engines.
So about a year ago I came a good deal on an L33 and picked it up. This is the all aluminum 5.3L truck engine. 9.9:1 compression and 799 heads which were used on the c5 z06 corvette. All in all a good engine at a good price.
So I pulled out the 7m about 6 months ago.
Bye bye 7m I will miss you
I really wanted to use the R154 since I had one and they have never failed me. I had heard that there were adapters available to merge the R154 with the LSx engines. So I went searching for info and found that very few people had actually done this. I found a guy local to me that was selling an R154 with a novak adapter plate and decided to take a look at it. The price was good and the trans was in good shape so I picked it up.
The novak adapter is a sandwich plate that uses a GM 621 bellhousing to attach to the engine. I liked this setup but the aluminum GM bell was very big and bulky in all the wrong places. I also picked up an LS2/LS3 c6 corvette oil pan. The dimensions looked good and it worked well on mock up but the GM bell caused me all kinds of interference problems.
I fought with it for a little while but finally threw in the towel and ordered an advance adapters AX15 to GM gen 3 bell housing kit.
Here is a comparison between the 2 kits.
The Advance Adapters kit was slimmer in all the right places and fit well in the tunnel with only a little BFH. Now I was able to hook the trans to the engine and get my mounts made. It was very easy and only took me a couple of weeks to get right.
Here is the engine and trans together for the last time. It took me 3 times to get the pilot bushing right. I finally found the right combination and used an adavance adapters bushing for the R150. I had to cut it down by a half inch and the final dimensions are 1.09"x.471"x1"
The advance adapters R150 bushing on the left and my cut down bushing on the right.
So here is the engine as it sits today.
I am still waiting to get my PCM back for an mail in tune. I should be able to start her up by the beginning of January if I can keep things going. I still have about a page of details to wrap up and she will definitely be ready to go back on the road in the spring.
