Reign_Maker said:Nate, Kamakazi Kams? TED cams? Can I get a link? Are the cams drop in? I mean, can you basically remove your old ones and drop these in while the head is still on?
I need to research these Tiltons... I know there is some kind of modification, just not sure what... From push to pull, or hydrolic or something like that...
Nate, good job... Own the PACIFIC NW! I'll take care of the ATLANTIC SE!![]()
SWEET!T.E.D. SAYS: said:NOTE: Race prepared Turbo motors will make in excess of 1000HP quite easily with the right combination
Reign_Maker said:Nate, you need to get into your thread and answer my questions, grrr agh ugh!![]()
I have an old set of cams that have some scoring on them, if you remember from my build thread... They arent good to just drop in, but I wonder if they would be good to regrind... The other thing Im wondering about is if I got these done, could I, while the head is still on the car, pull the stock cams out and drop the new TED ones in... I would like to dyno with the stock cams, then drop in the TEDs... Duane, I know you say Id have to shim it, but are you sure? With such a mild lift, I shouldnt, should I?
kwnate said:I'm letting someone I trust do this for me![]()
kwnate said:someone else is doing it. So all I'm going to do is sit back and relax![]()
