Just Another Rebuild
jdub
Feb 10, 2006
10,730
Valley of the Sun
This thermostat:
http://www.racerpartswholesale.com/mocal.htm
Yes, it's more expensive, but it is also something you never want to fail ;)
Plus, it has 4 AN fittings included (at $6 each) as part of it...no way it can leak.
This hose and hose ends:
http://www.racerpartswholesale.com/aero5.htm
Cost effective and very good.
The Permacool dual port, dual filter head will be fine...as will the oil adapter for the block. You'll need to get a NA filter stud (it's 3/4-16)...get the filter head and adapter to use this thread to since it's stock. Nice thing about ports on both sides is the flexibility and you can use a left over port for an oil temp sensor in the future:
http://www.racerpartswholesale.com/filtmt.htm
Oil coolers:
I have this cooler:
http://www.racerpartswholesale.com/cooler1.htm
These B&M coolers are very good:
http://store.summitracing.com/egnse...+cooler&searchinresults=false&N=+115&y=8&x=34
For your needs an 8"x11"x1.5" sould be fine.
Fluid dynamics 101 ;)
The fluid will follow the path of least resistance so in a dual you'd need matched filters or it'd just bypass the more restrictive one.
I think the layout of the dual adaptor would contribute to this even with matched filters.
