is it necessary to run a thermostat in-line with an oil cooler setup?
As compared to the usual stainless hose & AN fittings, yes it would be less expensive. I would use the AN push-lock fittings to make it easier to remove hoses in the future so you can work on the motor...the added expense is worth it. As mentioned earlier, Summit carries a line of push-lock AN fittings that is less expensive than AeroQuip or Earls...I've used them with no issues at all. Excellent quality fitting.
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
are these just like how some fuel lines are on some cars?
-t3d
Asterix
Lurker of Power
Vienna, VA
IJ.;1514124 said:
I'm using good quality heater hose but it will pop off the AN Pushlock fittings wehn hot, I have some thin Cobra Clamps that fit nicely between the barbs to prevent this happening, if you use normal clamps the barbs slice through the hose and it fails.
Spring clamps!
It's like wearing a belt and suspenders, but I do like spring clamps on my Aeroquip push-on connectors (as shown by IJ in post #34). The clamps are cheap insurance.
Asterix
92nsx
2,957
Clearwater, MN
ftw
Asterix;1515759 said:
Spring clamps!
Asterix
Well no it's NOT really, as I stated in the post the hose I'm using ISN'T designed for pushlock hose and WILL blow off when it's hot so the clamps prevent that, they're not Constant tension (spring clamps) they're a lock type band clamp.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
Here’s some info for everyone to file away!
Yesterday, I found out that there is a supplier of “un-official” Russell Fittings. AND they are offered at a fraction of the price as the official Russell Fittings.
The story is that the two owners of Russell Fittings parted ways. One owner kept the Russell name and moved to California.
The second owner moved to Florida and opened his own company and that’s where these fittings are coming from.
The below supplier is where you can get these substantially low cost, “un-official” Russell Fittings. I have already purchased and received some and they are VERY well made.
Performance Dynamics
804-427-5908 or 804-366-8321
www.performancedynamicsspeedshop.com
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
You must have called and ordered them? I don't see where you can order online.
the t3d
P B4 A
Sep 30, 2006
839
Titusville, FL
lol believe it or not i have some getfast1 parts that i'm currently watching. glad to know that they are not crap =0)...thanks for the info man!
-t3d
