black89t;1514101 said:^IJ what do you think of running these. they seem to be the same just summit's brand.
and -10 is what should be run with a shimmed pump correct?
http://www.summitracing.com/parts/SUM-220753/
mk3sons;1536184 said:Is this the right/okay hose to use with these fittings for this application?
http://www.summitracing.com/parts/SUM-220790/
Cz.;1536805 said:From what I have read from Aeroquip's site, not only is using clamps on push-lok fittings a waste of money, it can potentially cause the fittings to leak; don't use them.
IJ.;1536644 said:Can't use that style of clamp on a pushlock fitting, the barb will slice into the hose causing a spectacular failure.
Correct size hose and fittings and the correct Oil/Fuel resistant hose is needed to do the job correctly, never had one fail in 30 years of using pushlock after the first failure from using the wrong hose.
I run pushlock on the Engine Oil, Trans Oil and fuel here.
jdub;1537383 said:I've used Summit twist-tight hose/fittings and never had a problem with it...I did use the 3 barb AN type fitting vs the 2 barb NPT.
The Aeroquip fitting you linked to looks like a std brass barb...it's not push-lock...there is a difference.
Aeroquip makes good stuff - you won't go wrong with their version of the push-lock hose.
