just curious on the benefits of running with/without a thermostat?  and if absolutely necessary, what temp. would be best?
thanks!
-t3d
			thanks!
-t3d
Supracentral;1513425 said:Back in around, I guess it was 1999, I was installing an oil cooler (a pretty damned big one btw) on my 90T, and I didn't have all the fittings I needed to put the thermostat in.
So I ran without it. In January. It was about 20 degrees out.
I started my car the next day, let it warm up, and started to drive to work. As I drove, I watched the temperature gauge drop lower and lower. When I reached the toll booth on GA 400, my car was back in high idle warmup.
I pulled over to the side and let it fully warm up again, and finished my ride to work. In the afternoon when it was 40 deg out, it ran fine.
That one incident let me know exactly how much cooling capacity an oil cooler can have. And I will never run without a thermostat on one again.
Oil really only does a good job in a specific temperature range. Running without a stat could put you below that range.
Supracentral;1513425 said:Oil really only does a good job in a specific temperature range. Running without a stat could put you below that range.
the t3d;1513761 said:i know there was a choice between 180 and 200 so that's why i was asking
IJ.;1513684 said:You don't really get much of a choice they're usually 180f.
