Ian's right, a little bit goes a really long way (not many things suck up as much heat as water!)
Rakkasan, that'd be cool - we'll have a SoutEast meet @ Jay's place
suprahero;1229590 said:http://store.summitracing.com/partdetail.asp?autofilter=1&part=SNO-20010&N=700+115&autoview=sku
This is the kit I'm using. It installs rather easily and it has a green light that comes on when the pump is activated so you know it is working.
Here is the nozzle I'm using. It's 625 ml.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=SNO-40625&N=700+115&autoview=sku
I've never had a catch can installed on my car. As for the nozzle, that's what the guys @ Snow Performance suggested. He didn't ask me how much boost or anything I was running. He just asked me how much horsepower I was going to be making. I'm only adding three more pounds of boost, so I think this nozzle is way too big. Can you show me the caculations you used to figure up which nozzle I needed? I'm thinking about ordering two smaller nozzles and having it squirt from both sides. Thanks.10secdream;1229762 said:Do either of you not have a catch can connected?
Jay, How did you decide upon using the M15 nozzle? Reason I say this is that I used a calculator on the Devils Own site and it recommends a m10 nozzle for your application. I know the calculator is only an estimate but that is what it says.
I think the nozzle I have is spraying too much water. I can use my new camera and show you guys a clip of it spraying. I'll do it when I get back from the store. Thanks Ian.IJ.;1229798 said:J: I was worried about distribution using a single nozzle as my FFIM has a 90 degree turn into #1 so I went for the 6 nozzles, as the Meth/Water is only additive and not actually running the engine you'll be surprised at how little is needed to do the job and keep it out of detonation.
Thanks Doward. Maybe Mark will be up here when you're up here. That would be cool although we'd all have a lot to do. We're pulling his motor out and installing the 1.5jz, and you'll be tuning.............all supra work and no play makes us.........pissed. I'm sure we can fit in something to do though.Doward;1229803 said:Ian's right, a little bit goes a really long way (not many things suck up as much heat as water!)
Rakkasan, that'd be cool - we'll have a SoutEast meet @ Jay's place![]()
86_sports_1jz;1229825 said:thanks for the link suprahero. if you don't mind me asking, what is the differences in the nozzles? why is there different ones? is it kinda like the nitrous jets?
suprahero;1229877 said:Thanks Doward. Maybe Mark will be up here when you're up here. That would be cool although we'd all have a lot to do. We're pulling his motor out and installing the 1.5jz, and you'll be tuning.............all supra work and no play makes us.........pissed. I'm sure we can fit in something to do though.
suprahero;1230372 said:Thanks for the info. Hopefully some others will chime in and give their two cents worth on this setup. I will call snow performance today and ask them what they think and make sure they understood my setup correctly. I plan on making a video with my new camera to show you how much water it's pushing out. Hopefully it's as easy to upload onto photobucket as my last camera. Thanks again.
I can't take pictures right now because my car is at the painters shop. I will get pictures one day in the not too distant future..........I promise.....:x:jmcboost;1232591 said:Jay, did I miss the pics?? I don't see them anywhere. Or are you still "figuring out the camera"?:naughty:
D34DC311;1232619 said:Hurry up with this, I wanna see numbers!!
suprahero;1232622 said:I can't take pictures right now because my car is at the painters shop. I will get pictures one day in the not too distant future..........I promise.....:x:
I'm just as excited as everyone else, but I'm having to go through steps. Once I get it back from the painter, I'm going to weld in a bung to thread my nozzle into instead of having it threaded into the ic pipe like it is now. I'm scared it will eventually work it's way loose..........:aigo:
