If your looking to put 2JZ cams into your 1JZ, look at this
Sep 10, 2007
482
Virginia
whats the actual difference between usdm and jdm 2jzgte cams??
i know the whole "gentlemen's agreement" with 280hp vs. 300hp, but are the cams really different??
porsches4lunch
101
Miami
porsches4lunch said:
You Da man :icon_bigg I just got the Stinger from Arron as well so now i just have to start puttin it ALL together.
Got the cams and everything looks GREAT!!!!!!!!!!!! Thanks a Bunch Ben You da Man :thumbup: If you ever need anything, turbo wise please let me know.
Bigzavs
86.5 1JZ Single Turbo
Apr 21, 2005
2,267
Arlington, TX
couldnt tell you off hand, but the shop where my car is at has a few sets of both cams sittin around, so ill see if theyll take measurements on the cams and see what the difference is
Sep 10, 2007
482
Virginia
thanks, I am curious to find out. Either way, the 2jz cams can only help the 1jz...just a matter of how much.
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
from what the shop owner said to me, he hasnt really seen a huge difference between the JDM cams and the USDM cams
Sep 10, 2007
482
Virginia
I just found this info over on SF:
gmacrae;3870005 said:
Also, all this talk about the JDM cam being "mild" in comparison to the US ones:
Its 224deg/7.8mm lift vs 233deg/8.25mm lift - a TINY difference. We're probably talking about a 5rwhp difference from the cams alone. If the JDM ports are indeed better shaped because of the lack of the EGR, this would make up for the difference in the cam anyway.
There's is probably a good chance that toyota put the slightly bigger cam in the US head to make up for the interference of the EGR setup - anyone have any idea about this?
Gene
So I wonder what the actual hp difference is? 5hp sounds low...
Mk3Soup
Proudly Sponsored By SPER
Aug 20, 2005
Queensland, Australia
I've got JDM 2j cams sitting at the workshop waiting to get sent away for machining. will let you guys know how they go once ive got them in the car. :)
juan jz
197
Anaheim
I have this info,2JZ JDM cams run 224deg/7.8mm lift** and the 2JZ USDM cams run 233deg/8.25mm lift. Which ones do I use for my 1JZ, let me know asap so I can purchase this week end**
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
RacerXJ220;1148575 said:
Sent you a PM Ben. I've got some GSC S2 cams ready to be shipped your way.
As long as they are delivered to me before 4pm (shop closes at 430) i can get them to the shop and out to you the next day :icon_bigg
Bigzavs
Apr 21, 2005
2,267
Arlington, TX
GUYS!!!
Please Please, Package the cams tightly if you ship them to me, the cps tabs are very very very fragile.
I would suggest the Fedex Triangle tube for shipping, its what i prefer to ship in. You can package the cams very tightly in them.
Sep 10, 2007
482
Virginia
foreverpsycotic;1217014 said:
Can you get the JDM cams done, or just USDM?
both can be done. the USDM cams have SLIGHTLY larger lobes (I think it is referenced in this thread by me or BigZavs), due to the EGR equipment, thus provide slightly greater gains.
in other words, both can be machined, but the USDM cams are preferred over the JDM cams.
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
hey bigzavs, hopefully you are still offering this machining deal. i'm getting ready to buy a set of cams to send to you to get machined for my 1j. let me know if its still ok
