If your looking to put 2JZ cams into your 1JZ, look at this
1jz-soarer
Soarer
Oct 14, 2010
10
Calgary
Dgreen78;1868534 said:
FYI, I have found cam seals to work with the 2JZ cams in 1J head. Same ID as the 2JZ and OD of the 1JZ seals. This way you only need to machine the exhaust cam journal surface and reduce a lot of work. PM me if you need the cam seal part #.
Did anybody ever get a part number?
525gte
450
hoquiam
I am not sure but I think this is the part number for the seal that was mentioned TC12549. But I can not locate it anywhere
525gte
450
hoquiam
I am in the process of buying s1 2j cams. I'll try to take pics and post findings on the grinding process. I also have a bearings place down the road I'll go their and see if their is a seal That will work be for we grind the ends
seoul4korea
620
San Diego, CA
www.supraforums.com
I just did the swap myself not too long ago actually = )
525gte
450
hoquiam
Did you you use the gsc s1 cams? I had to put this project on hold I decided to work out some chassis bugs 1st
Tgood
All throttle no bottle
Dec 16, 2005
206
ennis/dfw
From what I've heard the lobes on gsc cams are to wide and sit to far forward to fit in a 1jz head
