Idle problems after SAFC, Lexus/560cc, and AFPR install. help needed
IndigoMKII
2,181
Madison, Virginia
jdmfreak;1981621 said:
You will most likely break the accordian hose doing that..I did.... .. If you warm it u and it's not totally dry and brittle you might get lucky but I dunno
3" is smaller than the OD of a Lexus afm. It'll take lots of time and patience with a little lube and some heat. If it was summer I'd say leave it on the sidewalk for a little bit.
reeds420
76
Phoenix
Update:
I put the SP61 back on with the stock accordion and symptoms are better, but not perfect. definitely doesn't bog down like it did in the video. I'd say my custom intake was at fault. Ill drive it around for a while and see how it acts. Thanks to all who chipped in
