Idle problems after SAFC, Lexus/560cc, and AFPR install. help needed
7M4EVR
695
fah, fah away
Dont let your SS line touch your alternator post...it looks dangerously close...if that happens you wont have to worry about your rich condition anymore.
reeds420
76
Phoenix
3p141592654;1980043 said:
Not to mention the thing being mounted to the fender where it will get torn off in an accident.
Its not bolted down yet. I'm putting it in another location when this all gets figured out
reeds420
76
Phoenix
Good look! Its not going to be mounted there. When its mounted the line is clear of the alternator. In the meantime I'll keep it clear. Dont need an explosion in my life right now
Oct 11, 2005
3,819
20
Thousand Oaks, CA
I'd mount it to the engine like all OEM installs. The fuel system is designed to survive a pretty bad front end accident that dislocates the engine from the mounts. The two hoses cross over to the body at the tunnel where they have the least chance of being torn.
reeds420
76
Phoenix
I agree, the AFPR needs a different mounting location. But back to my problem, does anyone think an o2 sensor could cause my condition or is it something else?
7M4EVR
695
fah, fah away
reeds420;1979969 said:
the car ran fine up until these parts on.
...just saying.
Take the safc out of the equation and turn the fuel pressure down on the afpr. Clear the ecu's learned adjustments and take it for a drive.
reeds420
76
Phoenix
7M4EVR;1980117 said:
...just saying.
This was going to be my next step after I replaced the o2 sensor. Will update tomorrow.
reeds420
76
Phoenix
O2 sensor didn't fix it, neither did another coupler leak I just found and fixed, neither did the deceleration air flow correction being disabled, and finally disconnecting the SAFC altogether didn't work either. Its something deeper. Gonna pull off the sp61 and see how it runs on the stock turbo and accordion hose. After I put it on initially is when my idle problems started but that was due to my custom intake leaking. Leaks were all fixed but idle still wasnt perfect. Back to the drawing board...
8,898
reeds420;1979970 said:
i know the SAFC has deceleration air flow correction for hot-wire style mass air flow meters but from what i've found it doesn't work on Karman Vortex. is this true?
TCCS is written with deceleration fuel cut. SAFC should only be trimming the signal, and should not effect it. That assumes all is hooked up correctly.
reeds420
76
Phoenix
Got it thanks!
Chris_87_Turbo
261
Princeton, TX
Not to thread jack, but trying to learn as well. Isn't the SAFC needed when using the lexus housing and larger injectors? What about the AFPR? I ask because I am planning on doing this upgrade as well and want to avoid any issues as this is my daily driver.
Chris
IndigoMKII
2,181
Madison, Virginia
Chris
Some say yes, some say no. I don't use a SAFC on my setup but someone will say its needed. You can play with the AFPR and the adjustment screw to keep the vF signal happy and get decent afr's in open loop. Mine idles at 15.1-15.4 and cruises at 14.7 then WOT is 11.1 and slowly goes to 10.7 before I shift IIRC.
Backlash2032
1,823
Nebraska
In theory all you need are 550 cc injectors and the Lexus afm. In theory works just like stock
Sent from my HTC6435LVW using Tapatalk
