That's a bummer!theKnifeArtist said:so i got an email back and they said the blue series light is only blue and i should try the little visor things to help with the visability issuebummer.
I just finished wiring mine in- the gauge is of course brighter, but the shade isn't *too* far off. Doesn't bother me a bit.Doward said:Yep, looks like the amber/white and green/white are the only ones that do it
I'm wondering how the green look with the stock gauges?
Mine works perfectly! I'll try to take some daytime pictures when i've got time off work, heh. So far i'm happy with it. I haven't hooked up my water temp gauge yet, though.Poodles said:anyone have one of their boost gauges that is working?
definitely. Thanks for the help guys!!!Doward said:Pics of the lighting at night (for a comparo)?
Lol make that two of us!adampecush said:i'm keeping my fingers crossed for 60mm green...patiently waiting for pics of the 52mm green.
Prosport said:*At this time we have not even begun to make a 60m Green/White Series. If we do it looks like it will be next year.
*Yes, you are correct. Blue is just blue.
*Also..ALL of our gauges are NOT dimmable.
*(color) is accomplished by powering up specific wires. I.E. if you want white connect white wire, if you want Green connect Green wire to 12v power.
*(Could I use a rheostat to adjust voltage to the gauge to lower the brightness) no, because they are LED's the voltage range between on and off is small -maybe 2 volts so basically they are either on or off.
